Old 02-07-2010, 01:41 AM
Default I need rubber shift boot !!
I would need rubber shift boot inside lokar leater shift boot to insulate cabin from noice and dust. I have T56 and have made raised the tunnel allready. So minor fabrication is not problem.
What have you used?
63 Z06
Old 02-17-2010, 11:46 PM
4th gen f-body T56 rubber boots are discontinued by GM. Any other ideas?
As i said it should fit under lokar "leather" boot.
63 Z06
Old 02-18-2010, 12:15 AM
deuce_454's Avatar
what about a hurst rubber boot?
you can cover it with a leather one... or what about a foam rubber seal between the transmission tunnel and the transmission.. and then just a leather boot in the cabin?
Jake: Hit it.
Old 02-18-2010, 12:33 AM
I just cut my hole for my insulation tight around my trans boot. The leather shifter boot is purely for cosmetics.
Old 02-18-2010, 07:49 PM
LSXfan LSXfan is offline
below is the GM part number for the heavy inner shift boot for a 4th gen F-Body
12542549 $19.51
Old 02-19-2010, 01:30 AM
12542549 $19.51
This might be it! Thank you LSXfan
63 Z06
Old 02-19-2010, 12:24 PM
Close but no cigar.. GM#12542549 is the rubber cover over shifter tower.The one wich mounts on transmission. Here i pic of the part i am looking for at 2010 camaro. Offcourse that cant be bought..I comes with the shifter cradle assembly
63 Z06
Old 02-20-2010, 08:41 PM
oops, I copied the wrong part number. This is it.
10267518
Old 02-21-2010, 05:31 AM
10267518
Okay,we try again
63 Z06
