Old 10-11-2010, 01:00 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default LS Crank Pin
Does anyone know the size of the crank pin and what it's made out of? I have the drill kit etc, just need some more pins.
www.hotrodderjournal.com
Old 10-11-2010, 01:19 PM
camcojb camcojb is online now
the Procharger kit uses a .250 pin. I am not sure they all use the same size though. Who's kit is it? Are you asking for diameter or length or both?
Old 10-13-2010, 02:14 PM
It's .250 as well.
Does it have to be case hardened? Or will cold rolled be strong enough?
Old 10-14-2010, 05:59 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
i used a roll pin on my vette and never had an issue. you can buy extra pins from most of the vendors that sell the kit. katech has or used to have a bag of pins you can buy without the tool and drill bit.
