Old 12-10-2020, 05:39 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by Ketzer View Post
Not a fan of something like a RacePak dash? (I definitely like the look of gauges over a LCD panel... just curious)
Jeff-
I have had digital dashes and like them. I used Dakota Digital in the Blazer and the Riv. They look great and work well. Also their cruise control works well also.
I wish it did not have so many modules but that is what makes it flexible
Stielow Engineering
Old 12-10-2020, 08:15 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I used the VHX version in my wifes LS swapped FJ40. Having the different modules really helped on packaging and space.
Jeff-
Old 12-10-2020, 09:20 PM
bkswede bkswede is offline
Simply amazing, as always!
Sent from my iPad using Tapatalk
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
Old 12-13-2020, 10:53 AM
Stielow's Avatar
More random photos of wiring. Not done yet but getting close.
Stielow Engineering
Old 12-13-2020, 10:59 AM
Stielow's Avatar
More random photos of other details.
Stielow Engineering
Old 12-14-2020, 06:09 AM
cpd004's Avatar
cpd004 cpd004 is offline
How did you set up your battery connections? Does your ground wire end back there or head up front?
Thank you.
1971 Firebird
2017 SS
Old 12-14-2020, 06:32 AM
Stielow's Avatar
Thank you.
I’ve alway welded in a lug in the back of the car to ground to. I know all the instructions say ground to the block, but I have never had an issue.
I have been adding a battery disconnect in the trunk on the negative side of the battery. Makes it easy to kill the power.
Stielow Engineering
Old 12-14-2020, 06:39 AM
Peter McMahon Peter McMahon is offline
why are some wires twisted?
Old 12-14-2020, 09:59 AM
andrewb70's Avatar
Those are probably communication wires for the BIMs and twisting cuts down on interference.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 12-14-2020, 10:13 AM
Stielow's Avatar
Andrew
Yes the CAN wires, wheel speed wires and temp sensors wire are twisted pairs. It cuts down on interference.
Stielow Engineering
