Old 05-11-2014, 12:39 AM
frankv11's Avatar
frankv11 frankv11 is offline
Default 2004 silverado RST magnacharger ,t56
Item Location (City/State):SoCal , long beach /paramount area
Price: $18.5k
77k miles
Description:
2004 4.8 true silverado Rst regency edition $18.5k
Magnacharger MP112 about 7-8 lbs boost
T56 w 2.66 1st gear ( close ratio )
Iski cam , pushrods & springs
42lb injectors
Walbro fuel pump
4.88 gears limited slip
Caltracs track bars
Centerforce aluminum flywheel
Centerforce dual friction clutch
GM slave cylinder / throw out baring
w remote bleeder
Mccloud scatter shield
Dual electric fans
K&N filter
JBA shorty headers
JBA plug wires
Fresh New head gaskets with ARP BOLTS.
Just got heads completely redone (had small leak on passenger
side , fixed it before it became a problem)
20" foose speedster wheels powder coated black
14" slotted and drilled Bear brakes all around
G force lowering springs , sway bar
Gaylord tunnel cover w upgraded SS hinges
Bed carpet
Toyo Proxes
Billet machined door handles ( no key hole )
Don't want to bore you with the list so let me describe it a bit
This a true regency fore those of you not familiar w these trucks
Here is a RST REGENCY complete write up. http://m.performancetrucks.net/forum...4997&styleid=4
This my second RST they are very nice trucks right out of CHEVROLET but were missing the GO but not this one. This is my daily driver so it's very well mannered until you punch it and will scare the c?!p out of you.
So as far as the mechanical part it's in tip top shape , I did all the work on it and all my maintenance. cutch / flywheel assembly has about 6 months use
Just spent about $1k on redoing heads
Truck has never been raced or dogged in any way
Truck shows wear ( cosmetically ) it's got your usual rock chips ,head lights are a bit hazy from leaving it outside overnight, front lower dam and tail (spoiler )have a crack on it. Powder coat on wheels got some chipping but can get those redone at no charge ( warranty )
Only trade considered woul be 2011 + DURAMAX HD CREW CAB with money out my pocket
TOW HITCH TO HAUL YOUR 69 CAMARO PROJECT AROUND
