Old 02-18-2009, 06:27 PM
Roarvette's Avatar
Roarvette Roarvette is offline
Default "ROARVETTE" '64 Corvette Coupe Garage Built
Many of you have seen some of my photos on this web-site since 2005. I am at the stage of begining paint and have a completed rolling chassis all nice and ready to drop the body on. I have had this car for 5 years, and if you have any doubt how things change, my son Rocky in the photos is now driving and is 6 feet tall!
Over the next few weeks, I will post the entire project for those of you that are into that sort of thing.
The saga begins with this "prime" piece of Corvette history. A 64 coupe sitting on a 67 chassis which had been a drag car for many years. From the looks of the welding on the frame, it probably had a solid rear at some point as well as a cage.
The body had only minor issues for what was basically a basket case. The chassis was also solid. But let's not kid ourselves here, it was basically a 40 Year Old POS.
But since I am cursed with a vivid imagination I thought it looked great...
500+ HP, 500+ Ft. Lbs, 500+ Cu. In. Yeah the numbers match!
Old 02-18-2009, 06:55 PM
Roarvette's Avatar
Default Current Status
This is what the chassis looks like now, as well as a mock-up shot of the complete car... I will fill in all the gaps in the construction.
Old 02-18-2009, 07:05 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
There is nothing cooler then a Midyear Vette.very cool build.Ron
Old 02-18-2009, 08:24 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Looks bad ass!
My LS7 69 Camaro
Old 02-18-2009, 08:34 PM
GHOSTDANCER GHOSTDANCER is offline
Old 02-18-2009, 11:12 PM
Sweet I love mid year coupe's
Old 02-18-2009, 11:19 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
My First Love, go with a Grand Sport Theme.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 02-19-2009, 12:50 PM
groovyjay's Avatar
groovyjay groovyjay is offline
I've been waiting for ever to see an update!
Old 02-19-2009, 12:57 PM
jy211's Avatar
jy211 jy211 is offline
Looks good! I would have hated to clean out the inside of the Escalade after hauling all those parts...
Old 02-19-2009, 04:44 PM
Roarvette's Avatar
Default Fuel Cell Installation
The first job I tackled was to remove the body. I made a contraption that went inside the car and fastened to the door hindge and door latch areas. I then put the arm of my hoist in the door and lifted away.
I then assessed the situation and jumped in. First tool, Plasma Cutter. I cut away the rear portion of the frame and the crossmember that holds the rear suspension was bisected. I the built a plate and tube structure to strengthen the area and to provide the front of the fuel cell compartment.
Then with 1X2 tube, I built a cradle for the cell and welded it on.
The benefits of the cell are lower center of gravity, saftey, and a built in fuel pump for the 502 Ramjet. The cell has a 22Gal. capacity and has all the fuel return lines, sender, and vent. Fuel pickup was placed in the rear center of the cell.
