Old 08-06-2014, 11:22 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I used copper nickel lines. Very easy to bend and flare. Just practice a few times with pressure on the hydraulic flaring tool. With a hydraulic flaring tool I was able to do the Quick Disconnect ends for the fuel filter. Do a search in the wheels, tires, brakes section for copper nickel.
Guy
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 08-07-2014, 10:43 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
This is some good info guys. Thanks!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-07-2014, 04:33 PM
66fury's Avatar
66fury 66fury is online now
try not to faint at the cost of coppernickel lines.1/2" fuel line is like 10$+ a ft.i think you can buy it from fedhill.com
mark
Old 08-07-2014, 04:52 PM
Hmmmm, I've used copper/nickel on brake lines before and liked it. I may have to check it out for fuel lines too.
I appreciate the feedback.
Old 08-07-2014, 06:00 PM
214Chevy's Avatar
I may think about doing the copper/nickel too. Although not rich, cost is not an issue. I don't mind at all paying for quality stuff.
'68 C10 swb
'72 Chevelle
Old 08-08-2014, 10:57 AM
parsonsj parsonsj is offline
Exactly. I'll never use anything but the copper/nickel any more. And we're talking about 12 feet of line, max. Fuel line isn't the place to get cheap.
John Parsons
Old 08-08-2014, 11:06 AM
wiedemab's Avatar
wiedemab wiedemab is offline
I am really considering using the Cu/Ni for both brake and fuel lines. I'm glad to see others have done fuel lines with good success.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
