Old 02-14-2015, 07:29 AM
parsonsj parsonsj is offline
Originally Posted by Andrew
Lingenfelter makes upgraded coolant pumps that are PWM. Isn't that what you want for this build?
Yes, and no. I wanted a PWM installation because I thought that's what GM did with the C6 ZR1. But they didn't -- they just run the pumps at full speed. They even run the pump at full speed in the C7Z06.
My main question was the 3rd wire in the provided GMPP harness -- which I now know is a 5V signal to the ZL1 pump to, you guessed it, run the ZL1 pump at full speed. That wire is not a PWM signal, and there is no PWM option anywhere in the GM lineup, which continues to the present day.
Even the LPE Stewart option just runs at full speed, and is advertised as flowing as well as the ZR1 pump.
So... I'll run the ZR1 pump at full speed. It simplifies the wiring, and wraps up all the engine wiring questions.
John Parsons
Old 02-14-2015, 09:09 AM
130fe 130fe is offline
Is the PWM fan control Function something that can be turned on with HP tuners?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 02-14-2015, 10:18 AM
Edit: Sorry! I thought you were asking about the coolant charge pump. Yep, the fans are easy to do.
John Parsons
Old 02-14-2015, 10:34 AM
samckitt's Avatar
samckitt samckitt is offline
HP Tuner dialog for the GMPP LS2 ECM tune. Others probably different.
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-27-2015, 10:15 AM
samckitt's Avatar
Hey Chris, your inbox is full.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-19-2015, 06:52 AM
samckitt's Avatar
I have a few left, anyone want one? $50 shipped.
Thanks,
Scot
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-20-2015, 02:52 PM
samckitt's Avatar
I ordered a different radiator, ordered the C6 fan from Amazon, ordered some little clips/brackets from C&R Racing and went to town. The Monte radiator is a little wider than the Vette radiator, so couldn't weld the brackets to the tanks like C&R racing does. I did on one side & had to use some 1/8" flat stock on the other side. Gotta find the bolts/nuts yet to bolt it on.
Here is what It looks like:
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-20-2015, 06:17 PM
Ron in SoCal's Avatar
^ that looks great Scot!
Props for staying with it and getting it done on this project
Ron in SoCal
69 Camaro in progress
Old 03-20-2015, 06:49 PM
SlowProgress's Avatar
That does look really good. I would be chicken to weld on a brand new radiator !
