Old 12-01-2016, 12:49 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Originally Posted by will69camaro View Post
Man I could go on for days. Look through my thread. Specifically the last year. I can get part numbers easily for all Holley stuff.
That budget for everything or turbo only? You'll eat that budget quick.
William, I don't suppose you happen to be on FGCC (First Generation Camaro Connection) Facebook page are you?
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 12-01-2016, 03:34 PM
mitch_04 mitch_04 is offline
My opinion...
Get an iron block engine. I don't believe that the displacement is very important since you are going to be using turbos, they will make up for a lot of displacement.
Remove the rotating assembly, put in main studs, rod bolts, and head studs. Have the rods honed as the new bolts will usually distort them. Same with the mains. Might as well balance it as well.
If you want to stick to your budget, go with a single turbo. Sucks, but twin turbos means 2 of everything. Even with ebay equipment you will blow that budget.
I don't know whether or not self-tuning efi will be able to adjust properly for turbos. I would use the original GM computer and haul it to the nearest tuner. It will be much cheaper and the original computer is more than capable.
Your money will be tied up in things like injectors to handle the power, ARP bolts/studs to help hold the engine together, and other little things. Use the turbo(s) to get your power. You can use Garrets turbo calculator to get an idea of what size of turbo(s) you will need, then purchase whichever brand suits your fancy. Quality and price tend to go hand in hand, however there is a large amount of people on the turbo forums who have $300 turbos pushing large amounts of power and, generally, reliable. Sure a couple have had things like oil seals and such go out, but for $300 you can get another.
I think your budget is do-able, but only if you do a single turbo with reliable components. Turbo is possible in the budget, but you'd have to deal with less reputable parts. Riskier, but not impossible.
Either way, that's my opinion. My build started the same, junkyard 6.0 with a single ebay turbo but snowballed. I've got a forged bottom end iron block 6.0 now, which will end up seeing a couple turbos down the road.
Good luck.
Old 12-01-2016, 06:33 PM
Rodknock's Avatar
Thanks for the info!!!
Well, I will likely bump the budget higher..haha
I'm not against going to a tuner. I suppose Denver (400 miles) or maybe Billings MT (100 miles) might have a tuner available.
I'm staying on the milder side of things. I think a 5.3 truck engine should be had fairly cheap, and could easily handle 700 HP. I hear you about studding the engine, and yes, I would have it balanced, since it's apart anyway. I actually have a decent machine shop where I live (so I heard). He does have an engine dyno, but I'm not sure if he is hip on LS EFI tuning, I'll have to talk to him.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
