Old 11-26-2008, 06:58 PM
Originally Posted by thedugan View Post
Thanks man so what your saying is bring the pointer to the "lonely" white line and then I'm ready for the distributor.
I'm trying to avoid taking the valve cover off. I gotta remove the procharger and the wiper motor first which isn't the end of the world but Id rather not have to unless its the last resort.
the "lonely" white line is not TDC and not where you want to be to drop in the distributor. The white line at the mark "0" is TDC, but not necessarily ready for the distributor to drop in either.
Pull the #1 plug, plug the spark plug hole with your finger and slowly turn the engine over by hand until you feel/hear compression push past your finger. You should be approaching the tdc line with the "0". I like to stop at say 16 degrees before tdc (or whatever idle timing you want to run). Drop in the dist with the rotor pointing towards the #1 plug terminal. Turn the key to "on" (don't crank) and attach the #1 plug wire to the spark plug, and ground the plug terminal onto something metal. With the key on slowly turn the distributor until the plug fires, and lock the distributor down at that position. Re-install the #1 plug and wire and the engine should be ready to fire.
Old 11-26-2008, 07:22 PM
thedugan's Avatar
thedugan thedugan is offline
Thanks Jody.
I'm running the Accel Dual Sync so wish me luck.
Phasing the rotor now
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 11-27-2008, 09:24 PM
thedugan's Avatar
When I read thru the Accel Dual-sync instructions it wants you to bring it to TDC then phase the distributor for the cam and crank LED's. Then lock it
Then turn the motor to 23-30 BTDC and then phase the rotor. If I follow these instructions then how the heck do you turn the motor backwards? I turn the motor on the balancer bolt so if I turn it backwards the bolt would back out? Like before I'm missing something here? confused. Help.
Jegs and summit sell the Proform tool that would work but there must be simpler way. I cannot get to the flywheel to turn it, the scattershield is in the way.
Doug L.
Old 11-27-2008, 10:09 PM
my instructions were for general distributor installs. To turn the engine backwards remove the plugs. If the harmonic balancer bolt is properly torqued it should not loosen without plugs.
Old 11-28-2008, 03:27 PM
thedugan's Avatar
Thanks Jody that took care of that.
Car does not want to start so gotta start troubleshooting the issue.
Have 17 pounds of pressure at the fuel rail gauge. Why so low
Car does start and then dies when I spray some starter fluid in the throttle body. Car then dies in seconds.
Gotta go feed the kiddies and then get them ready for bed so guess I gotta wait till Saturday to get back on it. Ill figure it out this weekend. so close.
Doug L.
Old 11-28-2008, 04:03 PM
it won't run with that low of pressure, so that's the first thing to figure out.
Old 11-28-2008, 04:42 PM
thedugan's Avatar
Jody I'm running the aeromotive bypass regulator near the tank. PN 13101.
Return from the bypass back to the tank.
Im going to put a gauge on it to see what kind of pressure I get back there.
On the front of the motor I have the fuel lines coming in to the back of the motor and the front of the rails is capped.
So a returnless system
Ill get out there in the AM and start checking it out
Doug L.
Old 11-28-2008, 04:59 PM
V8TV's Avatar
V8TV V8TV is offline
Good trick, Jody!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
