Do you have clearance issues with the 295 / 35 front tires?
I also have a Chassisworks sub-frame and I am having clearance issues. I have 9” x 18” wheels and 245 / 40 tires. The tires are rubbing the frame, fenders and inner fenders when you turn the wheels.
Any suggestions?
Thanks,
Mark
__________________ Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
Where did you order the bends from? SPD? I really need to do this to my car, I have a rubber 90 then MAF with a K&N stuck on the end. Just pull that one off and send it to your old Alabama pal !!!!
Kevin, I got the bends from treadstone aluminum somewhere near you.
Well our Speedtech switch panel finally cleared customs and arrived this morning. From my Days of Drag racing I remembered a company from Canada that made a really nice switch panel, that was set up with some self diagnosis features that could come in handy on the side of the road or the track. The switch panel connects through a Axial cable like your computer uses. All you do is hook up the power source to the relay panel and route your power wires to the components your running.
