Old 04-02-2010, 10:19 PM
tstarx tstarx is offline
Default To that person who owned my car.
What would you say to that individual, that owned your car before you. After you got it home and stripped it?
1) Just because it's carpet, doesn't mean shag carpet goes in a car.
2) Galvanized steel and sheet metal screw doesn't make for a good long term repair.
3) That noise you hear in the back is not knocking from your home-made 1/4" flat steel ladder bar, it's from your rear end grinding metal.
4) The rust and scale in your car doesn't give it character it's from your galvanized patch panels that you cleverly installed.
5) Last but not least. the gas tank is nice and secure, doesn't mean it's okay to secure your relocated battery to it VIA 3" sheet-metal screws.
Old 04-02-2010, 10:40 PM
buickfunnycar.com's Avatar
Angry Oh man...
Hang in there man...it usually get's worse.
www.buickfunnycar.com
Old 04-02-2010, 11:04 PM
Default well that's only 1 of them I own a 66 lemans to Great story
I'll tell the story of the lemans I bought fully restored for $800 one day.
Old 04-04-2010, 09:37 AM
rokketride rokketride is offline
1. You said rust in only one place and you've "been all over the car" ....you must be blind.
2. No, 3 out of 11 clips holding the heater box together is not adequate.
3. So, you did a FULL rebuild of the front suspension using dryrotted bushings?
4. The shifter arm shouldn't be the only thing holding the console in place.
5. When you replace the engine with one from a later era, you're not supposed to reuse the original timing cover/pointer on the newer balancer even though it will bolt on. Yes 5 degrees is a lot to miss TDC by.
Old 04-04-2010, 11:18 AM
Chris442 Chris442 is offline
1. Bondo is not an appropriate substitute for welding.
2. OTOH, the lack of welds made it easy to take apart the shoddy repairs, so thanks for that.
3. Apparently, people have widely varying definitions of "ready for paint."
4. When you go to spray primer, for God's sake, remove all the trim first. It was a massive PITA to have to remove all that overspray from otherwise good stainless.
5. Also, good idea to mask off the inside of the car before you spray primer, too. Not that much of it was worth saving, but it's just the whole idea.
Old 04-04-2010, 12:50 PM
70rs's Avatar
70rs 70rs is offline
And don't forget to remove the glass, trim, interior, lenses, urethane body parts, chrome,ENGINE and transmission BEFORE you take it to media blasting.....
It's amazing how much of the car will need to go in the trash if you don't.
Eric
Old 04-04-2010, 06:23 PM
GM Muscle's Avatar
"Would you like to come pick up all the meth and speed i found when i removed the bench seat?"
"Silicon probably wouldnt be my first choice for holding the window trim on"
"I just love the way the 80 grit DA marks on the GLASS stick out after i wash my car, tape is cheap man"
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-04-2010, 11:25 PM
ArisESQ ArisESQ is offline
HAHAHA
Old 04-05-2010, 12:17 AM
WOW! thought it was just my previous car owner who is a genius.
Old 04-05-2010, 06:19 AM
redfire69's Avatar
What a great thread, I'll play
1. Fiberglass is for boats and corvettes. It doesn't strengthen bad welds either.
2. Tar is for streets.
3. An air chisel isn't always the best tool.
4. Those threaded holes in the floors are for seat belts. Don't weld patch panels over them.
Ron
69 Camaro Redfire
