Old 01-21-2011, 10:23 AM
scherp69's Avatar
scherp69 scherp69 is offline
Default Speed Tech / Stainless Works header porn!!!!
These just showed up this morning. They are amazing. I'm really glad I decided to go with the polished ones. They will look sweet. These are the LSx ones for the Speed Tech subframe. They will also work with stock subframes and they have them for SBC and BBC. http://www.speedtechperformance.com/...cat/cat230.htm One question for you guys though....I'm putting them on a new L92. Am I okay to run these when I first get the motor going. I've read before that you should not run polished headers for breaking in rebuilt motors as it will turn them blue. Not sure if that's the same with crate motors. Thanks and enjoy the pics.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 01-21-2011, 10:34 AM
strtlegal's Avatar
strtlegal strtlegal is offline
I thought it was said not to run ceramic coated headers, but I think that was to break in a new cam. Dont think it will apply with your LS...
Looks good
70 Nova: LS2/Tko600. Speedtech Stuff
Chuck D
Old 01-21-2011, 11:58 AM
Rybar's Avatar
Rybar Rybar is offline
They look killer.
My motor had 50k miles on it and they still turned blue. Jason Huber told me to use oven cleaner to clean them, but I've never bothered.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-21-2011, 02:48 PM
BBC69Camaro's Avatar
See if you can find some beater headers (junk yard etc) if you are starting up a motor for the first time. They tend to run really rough and hot for the 1st 20minutes or so of run time. That's what I ended up doing, otherwise you risk discoloring or damaging any ceramic coating.
Old 01-21-2011, 05:13 PM
CarlC CarlC is offline
They are polished, not coated.
It's always a good idea to have a large fan blowing into the front of the car to help keep things cool during initial startup. Wiping down the headers with alcohol and a clean cloth just before startup will also help keep the tubes clean.
http:www.vaporworx.com
Old 01-24-2011, 07:03 PM
scherp69's Avatar
Thanks for all the comments guys. I'm really happy with them. I see that Stainless Works sell a compound that will take off the blue. As long as that works, I'll be happy.
I got them installed today. If you want to see more pics, check out my build thread. If you've ever needed a reason to do a LS swap, try installing a set of headers and you'll be sold. I didn't swear, throw a tool or smack my hand once. They go on so much nicer than small block headers.
If you're wondering how they sit in comparison to the subframe, they hang down just a bit
Mike
New Gen Splitters
LS3 and TKO600
Old 01-24-2011, 07:18 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very nice.
Old 01-25-2011, 09:23 AM
tobenk tobenk is offline
Awesome man.
Old 01-26-2011, 08:56 AM
Blake Foster's Avatar
They do look great. and like Mike said the LS and BB headers also fit a stock subframe with the rack conversion. and they all tuck up as high as possible in the subframe.
Blake Foster
Old 01-26-2011, 12:17 PM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
Beautiful! I had ss pipes on a motorcycle and they blued when the jetting was a bit lean. There is/was a product called something like blue-a-way (sp) that helped remove. I would take a scotchbrite pad and polish it away. When jetted well, the pipes were a golden hue.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
