  #38
Old 03-01-2012, 08:36 AM
ironworks's Avatar
The cool thing about the Ron Francis is that it does not you a temp sensor. So it has less parts to go wrong. But you have to manually set the fan switch with a heat gun since it does not use a Temp sensor. But once you figure out the temp it comes on at you just adjust it higher or lower to your desired setting.
