Old 09-21-2012, 05:46 PM
JasonElvisHeard JasonElvisHeard is offline
Default New- GMR AFX Upright Packages
GMR AFX-Front C6 Hub
GMR AFX-Brake Man Pro-Tour
GMR AFX-Z06 Monobloc
GMR AFX-Wilwood BNSL
Info and Investment structure coming soon.
Jason
Old 09-21-2012, 05:56 PM
Rick D's Avatar
Rick D Rick D is offline
More info please??? Testing???
Rick
Old 09-21-2012, 06:04 PM
I will be posting more info as I get everything up on our website. One thing I can tell you is that the first picture, GMR hub and AFX upright PAIR is going to retail at $1876.99
Jason
Old 09-21-2012, 09:19 PM
coolwelder62's Avatar
Jason
I have bought part's Jason.And they nothing but 1st. Class.
Old 09-21-2012, 11:23 PM
Track Junky's Avatar
Do you guys carry a Brake Man caliper/rotor set up to replace Bears C4 applications for first gen camaros with stock spindle? I am currently using Bears Track/Touring set up and am interested in going to Brakeman caliper and rotors up front.
Gaetano Cosentino
Old 09-25-2012, 09:16 AM
Yes. We have an option for you. I will pm you or please email [email protected]
Even if there is no direct bolt on kit usually we can figure something out.
Jason
Old 09-25-2012, 04:13 PM
Jay@GMR's Avatar
Jay@GMR Jay@GMR is offline
Default Brake Man Brakes
Hello Gaetano,
First off, thanks for the opportunity to supply you with the info for your potentially new brake setup. I put together some detailed info below for your review. Please let me know if you have any questions.
You would have a few options:
(1) F4 Caliper w/13” x .810 Pro-Cast Rotor …… $2,161.35
*add $300.00 for Brake Man Hub Kit
*add $50.00 for “Black” Ceramic Caliper option
*add $75.00 for slotted faced rotors (not necessary-more aesthetic)
(2) F4 Caliper w/13” x 1.25 Pro-Cast Rotor …… $2,261.35
*Above kits are complete with calipers, pads, plain faced directional rotors, brackets, hardware, and stainless lines.
*Above kits require aftermarket hubs…. yours or optional Brake Man Hubs (as the factory rotor has integral studs and bearings).
* Optional Brake Man Hub Kits come with bearings, seals & wheel studs (hub cost is not included in above kit cost as some customers may already have hubs or want to use other brands)
*If customer prefers to use his current aftermarket hub, center hole register and the depth from the hub face to the spindle mount will be needed at time of order (for hat fitment/offset).
*GMR recommends using NEW Brake Man Hub Kits.
Thanks, Jay
Old 09-26-2012, 04:16 AM
Amituk's Avatar
Amituk Amituk is offline
Coming to a build thread near you soon (see my sig)
I am using a full complement of GMR rolling stock on my car.
Incredible stuff
Build thread -NightHawk - 69 Camaro supercar build
Facebook -Like ProjectNighthawk
Twitter -@ProjNighthawk
Old 09-26-2012, 04:36 PM
Originally Posted by Jay@GMR View Post
Hello Gaetano,
Thanks, Jay
Thank you Jay. I am not ready at this time but that will be the direction I am heading. I will contact you when the time comes.
Gaetano Cosentino
Old 09-26-2012, 06:46 PM
Jay@GMR's Avatar
No problem, just let me know when the time comes or if you need any other info.
Just FYI, Brake Man use to recommend the BAER hub such as the ones you currently have for A, F, X applications so yours are more than adequit. But they now make their own so just wanted to let you know in case you want the whole Brake Man package!
Thanks again, Jay
