Old 07-16-2006, 11:11 AM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
Default Fuel Lines
Just a quick question, what size fuel lines are most of u guys running, stock or bigger, or depending on HP. I Plan on running between 400-700hp.
thanks
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 07-16-2006, 12:03 PM
Jay Hilliard's Avatar
I have a 1/2" line for a SBC 355 with 475hp.
Jay
Old 07-16-2006, 03:07 PM
Sales@Dutchboys's Avatar
In running at 3/8 on my 67 nova I bent out of tubing....
-Paul
dutchboyshotrods.com
269-823-2967
Old 07-16-2006, 05:25 PM
The difference in fuel line requirements from 400 to 700Hp is a lot. For 700HPI would go 5/8, or -10. 400HP will run on 3/8 or -6
Frank Serafine
Old 07-17-2006, 09:03 AM
thanks for the info, im still trying to make up my mind wether imma go with an n/a 350sb (450hp) or go with a supercharged 350 (650hp+). I just cant make up my mind...
1969 Chevy Nova
2007 Chevy TBSS
Old 06-23-2013, 09:15 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Default Fuel Lines
My 1979 Z-28 Pro-touring car has a Supercharged small Chevy. I run 1/2 inch fuel line part hard line, part braided A/N lines. With a High volume Mechanical pump.You can either / or run an electric ,your choice. I also run a Holley regulator, and a fuel log Filters.I run around 15+ pounds of boost.500+ HP. But I tend over build things That way you are less likely to brake or hurt stuff.. Engines like this tend to be hungry. And they need on the rich side. 3/8 line is n`t enough ,I learned the hard way.There was n`t enough volume.Also included a picture of mine. But you can figure what will best works for your application. Good luck to you,
Old 06-24-2013, 06:23 AM
Rick D's Avatar
Rick D Rick D is offline
HOLLY old posts!! almost 7 years later, I hope he has his fuel line all set! just messin with you!!!
Rick
Old 06-24-2013, 04:42 PM
Actually I don't. Seven years later my project has been put on hold for family and my engine has changed from a carbed 350sbc to a maggie powered ls3. Been accumulating parts while the body is in body shop jail. Fuel lines still haven't been chosen lol.
1969 Chevy Nova
2007 Chevy TBSS
Old 07-23-2013, 09:57 PM
bentfab's Avatar
bentfab bentfab is offline
What pump and reg are you running? Return style or dead head? Also what size pick up/outlet at tank?
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
