  #23
Old 12-29-2013, 07:24 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Originally Posted by Rybar View Post
Not really true I have a stroked 383 LS1 that made 496 rwhp.
Here is the thread that I pulled the dyno numbers. There is actually several on the L92 418. Dyno numbers will vary on several different factors.
http://ls1tech.com/forums/dynamomete...p-numbers.html
Although, if you do a supercharged LS 418, then the numbers will increase. My LS418 with Harrop TVS 2300 at 15lbs of boost was around 691 hp @ 5200 rpm and torque was 787 ft/lbs at 3900 rpm on the engine dyno.
Jeff
