Old 11-20-2015, 04:33 PM
paulk68 paulk68 is offline
Default tru turn Help
I have an email out to the guys at ridetech with these pictures but i was wondering if anyone else had this issue. The large stud tie rod does not go all the way up into the steering arm. I also can not fit the cotter pin on the top either. it is the same on both driver and passenger side
Old 11-21-2015, 06:27 AM
streetbird's Avatar
streetbird streetbird is offline
I think you used the drag link stud instead of tie rod
The French Frog
Old 11-21-2015, 12:34 PM
Thanks for taking a look, I thought that at first also but it is the tie rod for sure, I already mounted the drag link successfully.
Old 11-21-2015, 06:56 PM
SlowProgress's Avatar
Default Photo
Something is not quite right. Here is a photo of mine.
Old 11-22-2015, 06:40 AM
Thanks Scott, defanitley something off, looks like my weekend plans of wraping this front end up have changed to doing leaves instead
Old 11-22-2015, 08:15 PM
pull it back out and see if the tapered hole isn't reduced by powder coat, burrs or just plain out of spec.
Old 11-23-2015, 09:54 AM
Thanks all, the team at ridetech is taking care of it and sending me new arms with the studs installed to make sure they fit correctley.
Old 11-23-2015, 09:21 PM
Awesome! Good people there.
Old 11-24-2015, 09:44 AM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
That's some amazing customer service!
Kyle
Old 01-04-2016, 07:38 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Did you get everything fixed, Paul?
