Old 02-09-2016, 10:49 AM
andrewb70's Avatar
Originally Posted by Tony V View Post
I just want to clarify the above picture, and hopefully it doesn't lead to further confusion, but here it goes.
The connector on the left is technically PN 9440102, however vendors such as Mouser list it as being the same as PN 9440101. The 478 prefix is added by Mouser and indicates the manufacturer, in this case Kostal.
Ideally, you would use PN 9440102, but PN 9440101 works as well, if the oval circled cavity is hollowed out.
This information is straight from the Kostal blueprint, which is accessible through Mouser.
Andrew
Old 03-01-2016, 07:36 PM
Old66Tiger Old66Tiger is offline
Thanks for clarifying guys. I was hoping to have ordered and received all of the parts and did a write-up on it, but I got sidetracked.
Old 03-26-2016, 08:26 AM
I went into the controller with a needle nose pliers and just twisted the plastic pin out. Connector fits without modification
Old 02-09-2017, 12:30 PM
Obsin71Ls1 Obsin71Ls1 is offline
Old66Tiger, Andrew, et al. I wanted to say thanks for sharing these part numbers. I can't tell you how many hours I spent scouring the internet for them before giving up (this was before this thread). I owe you guys a beer
Old 02-09-2017, 12:41 PM
andrewb70's Avatar
Thank Bob for the heavy lifting. I was the one that managed to track down the little terminal for the PWM signal cavity.
Andrew
Old 04-15-2017, 11:42 AM
Larry R's Avatar
Larry R Larry R is offline
I would like to add my thanks to those who are responsible for getting the part numbers for the necessary connectors for the PWM module.
FWIW, I was doing some perusing and ran across this:
http://www.rockauto.com/en/moreinfo....1432165&jsn=10
It is a PWM module with wiring harness from Rock Auto.
Old 04-15-2017, 12:38 PM
andrewb70's Avatar
Thanks for posting that. Always good to have options. That other round connector is made by Yazaki I believe. It would be nice to find the part numbers and a source for other side...
Andrew
