Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 09-23-2018, 06:57 AM
calvin calvin is offline
Default WTB Tremec Magnum XL
Looking for one for my 66 Chevelle if anyone knows where to find one
Old 09-24-2018, 09:49 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Are you sure you want the XL? They were designed for newer Mustangs..
If you would like the regular Magnum (close or wide ratio) we can help you out.
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 09-24-2018, 05:00 PM
The only difference is the tail. It puts the shifter closer to your hip. Why have a bent shifter to get to your hand if you don't need one?
Old 09-24-2018, 06:00 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Need to hack the floor up a lot to fit a T56 Magnum
I just built a 66 LS3/525 with a TKO600 built for a 66/67 Chevelle so the shifter come up in the OEM position. Perfect with my 3.73s. Had to modify tunnel substantially to fit.
Why a a T56 whr the TKO600? 5 speed fits better, cost less and IMO no need for 2 overdrive gears.
Old 09-24-2018, 06:23 PM
slimjim's Avatar
slimjim slimjim is offline
I just built a 66 LS3/525 with a TKO600 built for a 66/67 Chevelle so the shifter come up in the OEM position. Perfect with my 3.37s. Had to modify tunnel substantially to fit.
I'm heavily considering this
NC
streamline 68 camaro
Build Thread here
Old 09-24-2018, 10:49 PM
JKnight JKnight is online now
As Todd will undoubtedly say “cause it shifts like a dump truck transmission!!”
I’m fine with my TKO but I’m sure the T56-based items DO shift better.
The Following User Says Thank You to JKnight For This Useful Post:
Vegas69 (09-26-2018)
Old 09-25-2018, 06:17 AM
Yes, I do prefer the T56.
You run 3.37 gear Vega?
I'm sure there will be some rework but that's ok
Old 09-26-2018, 03:16 PM
Vega$69's Avatar
Fat fingers. I run 3.73s
Old 09-26-2018, 03:26 PM
Vega$69's Avatar
This is what the tunnel takes to fit the TKO600
Name:  66 Chevelle Tunnel Mod.jpg
The Following User Says Thank You to Vega$69 For This Useful Post:
calvin (09-26-2018)
Old 10-09-2018, 02:53 PM
gnx7's Avatar
gnx7 gnx7 is offline
Do yourself a favor and get the T56 Magnum (close ratio 2.66) instead of the TKO600. Newer design, smoother shifting, will handle high RPM shifts... I'm pushing 1200rwhp thru a stock unit and shifting at 7800rpm without issues. Also offers VSS and Mechanical speedo outputs in addition to multiple shifter locations.
Is it harder to make fit.... meaning cutting the trans tunnel.... yes; however once you put the carpet back it isn't a big deal. I put one into my '69 Chevelle and won't regret it.
