  #15
Old 01-22-2019, 06:09 PM
slimjim's Avatar
slimjim slimjim is offline
Originally Posted by dhutton View Post
I didn’t do anything this sophisticated. Just added some small extensions to the floor pans with correct mounting nut locations. I cut the locating features off the bottom of the tracks. I had to remove a skooch from the rear outside track to clear the seatbelt mounting bolt hole. One of my goals was to retain the stock mounting holes in the event that I could not get these to work.
Jim’s solution is superior but I think it would exclude the Morris three point belts I wanted to use. His method would work better with the TMI console.
My method was really a result of installing the 5th gen dash, trans tunnel and center console. something to keep in mind depending on what console you use.
NC
streamline 68 camaro
Build Thread here
