Old 06-08-2021, 03:43 PM
aany001's Avatar
aany001 aany001 is offline
Thumbs up
Originally Posted by Musclerodz View Post
The bump up has to be tuned into the ecu, especially if its not a factory ecu. They sometimes provide a pigtail, but its not always turned on in the ecu. You can also over charge the ac system and put enough load on the compressor to kill the motor as well. Also make sure you have a large enough alternator to handle the amp spike when the fans kick on. That can also cause accessory load issues as several of the front drive kits out there only come with 140 amp alternator or less and that won't cut it.
Mike Im gonna check the pressures for sure..... good point! Also gonna load test my alternator and see whats going on? Im running a factory corvette alternator as well as the accesory drive.
Thanks guys!
