Old 09-25-2024, 03:08 PM
RDuke RDuke is offline
Default Exhaust question to quiet down 3"
Hey guys,
Quick question: Currently have full 3" exhaust (ultimate headers, flex pipe, Borla XR1 mufflers) through a Roadstershop chassis, behind a 1K hp LS3. It's too loud.
I can drop the center section (v-band clamps) and easily replace it with either a resonator or another set of mufflers before it gets to the rear XR1's in front of the rear axle.
What would you recommend? I'm currently looking at a set of 3" atak mufflers with an offset pipe to make it easy or a set of 3" borla resonators. Anything else I should be looking at? Suggestions?
Old 09-25-2024, 03:28 PM
camcojb camcojb is online now
I don't have a personal recommendation, but I see that RS uses resonators and mufflers on most of their builds.
Old 09-25-2024, 11:21 PM
Steve68 Steve68 is offline
Cats are an option, help with sound and exhaust/gas smells,
The Following User Says Thank You to Steve68 For This Useful Post:
camcojb (09-26-2024)
Old 09-26-2024, 06:02 AM
You’re likely not going to find a cat that will survive with that horsepower. Unsure if that’s changed in the last several years.
My car with similar horsepower runs vibrant resonators. Maybe they’ll help. Mine isn’t loud but setup is a bit diff with turbos as the “mufflers.”
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following User Says Thank You to will69camaro For This Useful Post:
Old 09-26-2024, 06:34 AM
Yea, I don't think Cats will survive. I'm also a bit limited in height too as the floor pan drops a little into the space. I right now the main pipes next to the J-pipes are about 1/4" off the floor pan and heat it up quite a bit. I have 4" of frame height, so anything like a 5" resonator is going to be the lowest point under the car and be an issue.
Borla makes a 4" resonator (400939) that says to quiet it down 2-3db. I may still be able to fit a J-pipe in the space too. Need to do some more measuring today.
The Following User Says Thank You to RDuke For This Useful Post:
Old 09-26-2024, 07:54 AM
I run the Vibrant Bottle Resonator, this one specifically: https://vibrantperformance.com/bottl...onators-v1250/
It's 3in inlet/outlet, OD 4in, and 12in long. As said i have turbos to do the primary "muffling" but my car i feel is VERY tame sounding, and makes >1000rwhp.
Texas A&M BSME 2008
1992 Corvette ZR-1
The Following 2 Users Say Thank You to will69camaro For This Useful Post:
camcojb (09-26-2024), fleetus macmullitz (09-26-2024)
Old 09-26-2024, 09:37 AM
Panteracer's Avatar
I put a second set of 12" spintech spiral resonators
after my extreme mufflers on my GT-1 trans am car
Exhaust is 3" in this configuration... it can make a 105 db
at Laguna and 103 db day at Thunderhill... still pretty loud
My other exhaust is a 4 1/2" straight pipe.... not sure what
DB that hits but my Pantera with straight 3" is 109.7 at Laguna
Seems like anything with glass packing blows out after a while
Bob
The Following User Says Thank You to Panteracer For This Useful Post:
Old 09-26-2024, 02:43 PM
Thanks guys,
I went with a set of Vibrant resonators, 18". Shipped this afternoon from Summit. Hopefully this will help.
The Following 2 Users Say Thank You to RDuke For This Useful Post:
camcojb (09-26-2024), will69camaro (09-26-2024)
Old 09-27-2024, 12:08 AM
Sorry, didn't see the HP rating, probably would burn the cats out,
resonators probably the best,
will69camaro (09-28-2024)
Old 09-27-2024, 06:09 AM
dontlifttoshift's Avatar
When is it too loud? Idle and cruising is okay? What about wide open throttle? Is it too loud or just obnoxious sounding?
Is this LS3 supercharged?
*** edit ***
Just looked at your build thread and saw the engine. Now I am really curious about the when it is too loud. I have a theory but I will wait for your response. I don't think the resonators are going to change much for you, though.
Donny
