After determining that the pan will be acceptable......I decided to pull the engine out again so I could finish up changing the steering box from that super slow stock ratio manual box to a Jeep Grand Cherokee power steering box....Three turns lock to lock.......I also can now finish "Clearancing" the trans tunnel to fit the new trans..........and I also removed the gas tank so it can be modified to work with the new fuel system.........also removed were the front Drum Brakes which will be replaced with Discs........Mark is bringing over the balance of parts next week so we can do the final assy...........This was hard the first time I did it , but..........LOL...........Also here are some more pic's from the underside of the car..........Just Amazing......
look up your car on rock auto and you will get the correct rag joint
1967 CHEVROLET BEL AIR 5.3L 327cid V8 : Steering : Steering Gear Price Core Total
LARES Part # 973 Power Gear; Reman; 3-3 ¼ turns lock to lock. One of our most popular parts
Budget (3 bolt mount; 3 - 3-1/4 turns; Includes Steering Coupling Assembly)
Part ImageNext Image
$80.79 $50.00 $130.79
LARES Part # 975 Power Gear; Reman
Budget (3 bolt mount; 4 turns; Includes Steering Coupling Assembly) (Only 6 Remaining)
$80.99 $50.00 $130.99
LARES Part # 970 Power Gear; Reman; 3- 3 ¼ turns lock to lock. New coupler available.
OEM w/ casting # 6 or 76; Works w/ Lares Steering Coupling Assembly 201
$80.99 $75.00 $155.99
LARES Part # 971 Power Gear; Reman; 4 bolt mounting; 3- 3 ¼ turns lock to lock. Variable ratio worm gear. New coupler available.
Race car; Works w/ Lares Steering Coupling Assembly 200
ACDELCO Part # 36G0103 {#19321358} Professional; Remanufactured Power Gear
Part Image
* Stocked in outlying warehouse--shipping delayed up to 2 business days
$109.79 $50.00 $159.79
A-1 CARDONE Part # 276537 Reman. Power One of our most popular parts
Inline filter available
Part Image
$102.79 $75.00 $177.79
LARES Part # 1274 Manual Gear; Reman
OEM; Works w/ Lares Steering Coupling Assembly 202
$114.79 $75.00 $189.79
LARES Part # 11274 Manual Gear
$192.79 $0.00 $192.79
LARES Part # 974 Power Gear; Reman One of our most popular parts
10:1 Fast Ratio; Budget (3 bolt mount; 3 - 3-1/4 turns; Includes Steering Coupling Assembly)
$162.79 $50.00 $212.79
ATSCO Part # 6572 Remanufactured
Front; Power steering; w/ 3 Bolt Mounting (Only 3 Remaining)
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$143.79 $75.00 $218.79
ATSCO Part # 6537 Remanufactured
Front; Power steering; w/ 4 Bolt Mounting
$155.79 $75.00 $230.79
I don't know your plans for A/C, but if you are trying to keep the factory stuff, you can swap the evaporator core for one from a later car (I used '79 Trans Am in my '72 442) with the accompanying receiver/drier and cycle switch to give you a cycling compressor.
In my Jeep, I am using the '79 T/A evaporator with the compressor from my 2008 LY5. Nice and cold!
__________________ You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Thanks for the info...........Marks A/C guy is going to finalize that part of the conversion.............
