Old 11-22-2020, 04:40 PM
Rodknock's Avatar
Rodknock Rodknock is offline
Originally Posted by MtotheIKEo View Post
A tanks inc 450 pump module is $340. That will support your hp goal.
+ some kind of regulator (~$150), you are about $500 in ignoring plumbing which will be needed for either option.
Vaporworx module is $430, which just controls the pump.
Not sure what CTS-V fuel pump module assemblies are going for. OEM modules look to be ~$800, aftermarket about the same.
The Tanks Inc tank won't accept an OE style module so you will need to weld in the mounting ring, ~$200 in hardware + installation.
So now you're ~$1500 in. (unless I'm misinterpreting the Vaporworx site)
There is no arguing that the Vaporworx setup is better. Really depends on your intentions with the car as to whether its worth it.
The intentions with the car are 99% street/highway driving.
The other 1% will be AutoX and maybe occasional drag strip trips, with max performance in those areas not required. Just be for fun, not competition.
That's why I figured the 450LPH pump will be sufficient obviously, my main concern is whether it will be too much if I opt to run lower power levels initially. Just don't want to purchase two pump if one will do it with proper control.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
TMI interior
4L80E
6.0L TT? Maybe
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 11-25-2020, 01:21 PM
pannetron's Avatar
pannetron pannetron is offline
+1 on one of Carl's VaporWorx controllers and a CTS-V pump module. I have that (boost referenced) feeding an E-Force blown 6.2L LS. A step up from that is replacing the GM pumps with DW pumps as another poster mentioned. The GM fuel pump buckets are good.
The Following User Says Thank You to pannetron For This Useful Post:
Rodknock (11-25-2020)
  #13
Old 11-26-2020, 12:01 AM
Rodknock's Avatar
UGH!!!
All this new fangled EFI stuff I have to learn. Maybe I shoulda stuck with carbs
John Rodko
69 Camaro RS/SS
DSE mini tubs
TMI interior
4L80E
6.0L TT? Maybe
Old 11-26-2020, 08:48 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Originally Posted by will69camaro View Post
Honestly with that as a max, i'd look at using a V (or ZL1) module and replace the pumps with DW300C pumps. Get a vaporworx controller to control it all and let him know you're using those pumps. I think that would get you VERY close to 750rwhp and maybe even on E85.
https://www.deatschwerks.com/blog/ne...-fuel-pump-kit
This is what I am running to support 750hp but I also have a tank like will69camaro with one side having a blank for the pump hat for future hp possibilities. I know pump size boosted vs n/a is different. Carl will direct you where you need to go. It is more straight forward than it might seem with Vaporworx.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 2 Users Say Thank You to cjfirstgen For This Useful Post:
Rodknock (11-26-2020), will69camaro (11-27-2020)
