Old 10-11-2021, 01:31 AM
DRJDVM's '69's Avatar
Default Temporary paint protection film
I see a lot of guys/shops using the disposable plastic films on their cars during assembly, motor work, interior work etc to help protect the paint, door edges etc---- I've seen some that are the clear blue tint and some that are solid white. I'm assuming this is the generic carpet protection film you can buy online etc ?
In the past I've just used masking tape, but that's a PITA to cover larger areas
Any suggestions? I want to to stick but not be a huge PITA to remove either
Old 10-11-2021, 07:09 PM
joeko23 joeko23 is offline
This is the best and cheapest stuff
3M Welding and Spark Deflection Paper, 05916, 24 in x 150 ft,Brown https://www.amazon.com/dp/B000PENDAK...9WZN3S147BYWDM
Xpel also makes one but it’s more expensive and I don’t think it’s as thick as the 3m welding paper.
XPEL TW18T40 Clear Tracwrap 18" x40' Temporary Paint Protection Film https://www.amazon.com/dp/B076CVP65S...Y934XXHJ?psc=1
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
The Following 2 Users Say Thank You to joeko23 For This Useful Post:
camcojb (10-14-2021), zz430droptop67rs (10-11-2021)
Old 10-12-2021, 08:35 AM
syborg tt's Avatar
Thank you and I just ordered some.
marty-mj
Old 10-12-2021, 12:04 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
FWIW I left the 3M stuff on WAY longer than it says to with no issue. Simple Green removed the left over adhesive residue pretty easily too.
Erik
69 Camaro
Old 10-14-2021, 03:06 PM
Thanks guys...
I've seen the 3M welding paper used a lot during fabrication to help with welding sparks etc... probably a bit hard core for what I'm looking for
The other stuff looks like some good options.... still a bit pricey. For my application its going to be more for protecting the paint while its at the interior shop, so more a temporary rather than longer for track days and long term protection.
Old 10-14-2021, 06:54 PM
7TSS's Avatar
7TSS 7TSS is offline
This is the same as what I've used in the past.
https://www.amazon.com/Protective-Ad.../dp/B082FS6KJH
Goodwin
The Following 2 Users Say Thank You to 7TSS For This Useful Post:
camcojb (10-14-2021), XLexusTech (10-18-2021)
Old 10-15-2021, 08:10 PM
TechNova TechNova is offline
the 3M paper works well but remember it's name, it is spark deflection paper. It does not protect against sparks sitting on it on horizontal surfaces.
The Following User Says Thank You to TechNova For This Useful Post:
dhutton (10-16-2021)
Old 10-18-2021, 12:55 PM
Pro Touring Store Pro Touring Store is offline
The best stuff I've found to use is Uline glass protection film.
The spark deflection is good as well but I really dislike the residue it leaves. Especially on a new paint job.
Dale Schwartz
www.ProTouringStore.com
The Following User Says Thank You to Pro Touring Store For This Useful Post:
Ketzer (10-19-2021)
Old 10-18-2021, 07:34 PM
Nice thank you !
Do they make this in Clear ?
Old 10-19-2021, 01:32 PM
7TSS's Avatar
Originally Posted by XLexusTech View Post
Nice thank you !
As previously mentioned Uline has it in clear or blue.
https://www.uline.com/BL_6408/Glass-Protection-Tape
Goodwin
