Old 03-26-2020, 01:53 PM
H8tulooze's Avatar
H8tulooze H8tulooze is offline
Default Need help Socal
Hello, Im trying to start my LS9 but no luck. Power at the coils, injectors, had the ECM Vats turned off, fuel pressure at the rails but just cranks. I have two grounds from the engine to the frame and I just ordered two more to be safe. Anyone ever come to someones house to help get started? Willing to pay.
Thanks,
Stacy
1967 SS Nova LS1 SOLD!!!
1967 SS Nova Canadian LS9 800HP
1965 Chevelle 2 Door Wagon
1965 SS Malibu Convertible
Old 03-26-2020, 07:28 PM
camcojb camcojb is online now
Do you have an rpm signal when cranking? If you do I'd make sure the VATS is properly removed. If not, then start checking the crank/cam sensors and wiring.
H8tulooze (03-26-2020)
Old 03-26-2020, 08:36 PM
H8tulooze's Avatar
Where can I check for a RPM signal at?
Old 03-26-2020, 08:45 PM
Che70velle's Avatar
The easiest way to see what’s going on is to find someone with HPTuners to come over and plug up while your cranking. I had same issue as you once with a build and found my MAP sensor connector was mis-wired. I would have NEVER found that without the software. Bottom line is...it’s always something simple.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
H8tulooze (03-27-2020)
Old 03-27-2020, 11:11 AM
H8tulooze's Avatar
Thank you, maybe I can pay someone with HPT to come check it out.
