Old 04-18-2019, 09:55 AM
Roscoe03 Roscoe03 is offline
Nice to see that you haven't given up on your project. Can't wait to see the finished product!
Old 04-19-2019, 07:54 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
caint give up now! I'm getting older I'm going slower have to take breaks more often plus having more cars, I used to be able to concentrate on one car I got one old third gen back and picked up another orphan third gen that also is getting some rehab the orphan was a lucky score it had a rare dual air SLP intake on it- thats really all I wanted to buy but seller wouldn't split them up when it came home it had a rare Dana 44 in it so it was like hitting a jackpot the car is a 90 formula 350 carshowing 71K
but now I have to push this off a bit and concentrate on the 69 I wanna get it running at least then get it to the painter guy - member here- Mr. Hutton
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 05-13-2019, 08:37 AM
ZMAN1969's Avatar
Little update column installed - sort of
this took longer than expected as I had to install firewall pad and I already had fuse block, pedal hangers and parking brake installed Ugh I hate having to remove and reinstall then I spent another couple hours looking for Borgesen joint for column - gave up and bought one so some day I will find the one I lost at lease installing shaft wasn't too bad the good news is it fit with the 2015 Z28 headers that I went with
so I'm happy something is done now the steering column a '80?? model didn't quite plug and play with the AAW classic update harness as I expected the T/S harness plug had to have a new connector installed (included in the kit) and it then clipped right into harness plug BUT the Ign switch plug didn't fit the later switch turns out the AAW harness fits stock 1969 Firebird column and they are different than the later so I called AAW and they have another plug that will need to be repinned to make this work
OK my rant here: if your going through installing an update harness why would AAW think your not putting a newer column IE tilt ot Ididit or and wire it for the common Ign switch and note that if your using the original 69 Firebird column you will need a new switch or include one that would work since this kit was supposed to be so inclusive?? Ok what do I know
so I will wrestle with that next opportunity I have
Funny thing is now when the steering wheel rotates L&R the front wheels turn?? WTH?
LS6 6speed
1999 Firehawk
Old 05-14-2019, 10:14 PM
qnitro's Avatar
qnitro qnitro is offline
Nice meeting you today.. Im starting to think Don knows everyone...
Love the project and the car talk, even though the wife broke into it
Eat or be eat'n
The Following User Says Thank You to qnitro For This Useful Post:
ZMAN1969 (05-17-2019)
  #65
Old 05-17-2019, 07:03 AM
ZMAN1969's Avatar
you too! nice to see others with a bad car habit! Car-holics anonymous anyone?
Nah that's for quitters!
LS6 6speed
1999 Firehawk
Old 08-08-2019, 07:35 AM
ZMAN1969's Avatar
So I have some more progress~ I bent up some sheet aluminum to mount the cooling fan
well I ended up doing twice
I like this now but this fan is kind of thick and will be a little hard to work the 4" air intake by it. If I end up using this I will add some sheet rubber between the brackets and tha radiator so it doesn't cause a leak later
Vintage Air install is next on the list stay tuned...
LS6 6speed
1999 Firehawk
The Following User Says Thank You to ZMAN1969 For This Useful Post:
Roscoe03 (08-10-2019)
  #67
Old 08-14-2019, 03:01 PM
ZMAN1969's Avatar
Another update: making it cool : literally
well, Vintage Air has pretty good instructions so its going fairly well-so far,
I did find out with the Holley Bracket you need 97-01? Vette Tensioner and idler pulleys and the idler pulley goes on the tensioner and the tensioner pulley is mounted to bracket solid- the belt would of been K060960 except I used a U/D pulley so I needed smaller belt so 2 trips to O'reilly's auto parts Bam! got my belt
chipping away at my list of to do's !
LS6 6speed
1999 Firehawk
Old 08-19-2019, 10:07 AM
ZMAN1969's Avatar
Some more progress - think were over the hump of Evap box in and out repetitions but time will tell, My son did the AC control mods and it was PITA not real good instructions - not mentioning that other brackets needed to be removed till it was together also bought new knobs and lend for it and a BIG thank you to him!
still need to install ducts and wiring but I think that'll be easier I couldn't imagine one person doing this install without a helper
LS6 6speed
1999 Firehawk
Old 08-23-2019, 03:56 PM
ZMAN1969's Avatar
Now here's a score that I'm glad I did 6 hour road trip to Oklahoma for minimal rust and no repairs ever and under 5 bills- what y'all think?
I'm glad I talked myself into it
LS6 6speed
1999 Firehawk
The Following 3 Users Say Thank You to ZMAN1969 For This Useful Post:
dhutton (08-23-2019), fleetus macmullitz (03-04-2020), Roscoe03 (08-24-2019)
  #70
Old 08-23-2019, 05:20 PM
ScotI ScotI is online now
You did good. Very good.
