Old 08-26-2016, 02:04 AM
Nitrous Nitrous is offline
Default T56 Magnum Shifters
I have a T56 Magnum in my 69 Camaro. The stock shifter isn't horrible but I feel like I might be a little more confident if the shifter would center harder than it does so that when I shift hard from second to 3rd I'd feel a bit more confident.
Are the aftermarket shifters like the black jack or white lightning much better when it comes to centering and providing a short throw?
Old 08-26-2016, 07:41 AM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
If it's not leaking yet, don't change it until Bowler comes out with their shifter.
Donny
Old 08-26-2016, 08:31 AM
paulk68 paulk68 is offline
do you have any info on the one that they are working on?
Old 08-26-2016, 10:47 AM
Supposed to be awesome and not leak. That's all I know.
Donny
Old 08-26-2016, 02:40 PM
Donny you're the best ...love the answer lol "be awesome and not leak" lol well s*** im sold
Old 08-26-2016, 03:23 PM
What more could you want from a shifter?
Donny
Old 08-26-2016, 05:55 PM
Looks ...price ....quality or is that all included in "awesome"
Old 08-26-2016, 06:42 PM
Bah, details.
The stock Magnum shifter works fine, I think. The inability to keep the trans fluid inside the trans is what makes me crazy.
Bonus points to anyone that comes up with a shifter that doesn't leak _and_ has a manual reverse lock out.
Donny
Old 08-27-2016, 02:57 PM
Sieg's Avatar
Sieg Sieg is offline
The problem I had was when running the shifter in the front position over the top of the gear. Without a baffle over that gear sealing will be a challenge.
I altered my '69 Camaro stock console to use the rear mount position and that neutralized the leak problems. With my NGR quick release steering hub and the rear shifter position the relationship is ideal for me.
The new generation of Hurst Blackjack shifters utilize this seal which I work with them on as the first shifter leaked like a sieve when mounted in the forward position.
Here's the new shifter seal:
Regarding the shifter itself, I haven't driven a car with better gate/throw shifter. Especially taking into account the length of the shift lever.
I also had an early version of the White Lightning and it leaked worse than the Hurst. It felt similar to the Hurst but I'd still give the Hurst the edge.
The Following User Says Thank You to Sieg For This Useful Post:
Flowmaster Exhaust (07-10-2018)
Old 08-27-2016, 03:31 PM
Do the Hurst and Whilte lightning actually shorten the throw much over the factory tremec shifter? Do they center harder with tighter springs or is it about the same?
Pretty bad these companies have to keep redesigning their shifter because they keep leaking. Figure it out BEFORE you put a product to market.
