Old 08-01-2021, 11:12 AM
Musclerodz's Avatar
Do you have a seal in it? It will completely change how it fits.
Mike Redpath
Musclerodz & Customz
facebook page
The Following User Says Thank You to Musclerodz For This Useful Post:
jarhead (10-20-2021)
  #1562
Old 08-01-2021, 03:43 PM
Sonar Chief's Avatar
Wink
No I don't .... hmmm, let me go find my seals
Old 08-01-2021, 04:05 PM
dhutton dhutton is offline
Make sure you use the hollow core Metro.
Sonar Chief (08-01-2021)
  #1564
Old 08-02-2021, 08:22 PM
Thanks, they are on order ....
Old 10-16-2021, 11:22 PM
Smile Update 10/16
WOW, been some time .... I did not like the fit of the Anvil carbon fiber trunk lid so I asked to return it, no questions asked they said issued a RA and I sent it back. It was 3/8 high in the middle and low on the front corners, now to beat on the AMD lid some more
Other than that I have been busy with work ... working on classic cars is cool except some people should not be trying to do their own electric mods or rust repair. I have been working on a 69 VW bus that some ha hoo did the metal/ rust repair and warped every panel that he worked on, grrrrr.... Step away from the welder cuz you are an IDIOT!!!!! Been using my Big Kids sanding blocks to get her straight ... not that there is a straight panel on a VW bus
So I got my inner fender well repainted last weekend and thought something was wrong, it didn't match the other one .... hmmm, I even called the paint jobber and asked about the ratios. Well, come to find out the satin black is mixed 4:1 not 3:1, so I had to respray the inner wheel well today.
Learning a lot at work, been working on a 69 Mustang fastback, 58 Impala, 88 Thunderbird, 76 Bronco, and a 55 Thunderbird. Having a blast, they pay me to work on classic cars ... I learned a lot about the Dakota Digital VHX system installed on the 58 Impala troubleshooting the fuel level sending unit ... pretty cool unit if you follow their directions, lol.
Thanks for looking ... I'll have some pixs next time.
The Following 9 Users Say Thank You to Sonar Chief For This Useful Post:
camcojb (10-17-2021), clill (10-18-2021), dhutton (10-19-2021), jarhead (10-18-2021), Roscoe03 (10-20-2021), Spiffav8 (10-17-2021), Steve68 (10-17-2021), syborg tt (04-04-2022), waynieZ (10-20-2021)
  #1566
Old 10-19-2021, 06:25 PM
marksawatsky marksawatsky is offline
I have just begun the build of my 1967 Camaro and this thread is going to prove to be very helpful. I am doing many of the things that you did. Thanks for showing your work. With the Vintage Air system, is it necessary to weld up the big hole in the firewall where the original heater goes?
The Following User Says Thank You to marksawatsky For This Useful Post:
Sonar Chief (10-19-2021)
  #1567
Old 10-24-2021, 09:17 PM
That is why we share our progress with the dos and don'ts. I welded a panel where the original heater plate was and covered it with an Al plate w AC inlets.... Finch firewall plate.
Old 04-03-2022, 06:01 PM
Cool Been some time ....
Wow, time has flown by ... here's an update that deserves sharing. Been working in a classic car restoration shop here in Littleton CO and loving my job. Do what you love but call it work is mental happiness. I have been working on all sorts of cars, learning a lot, and always looking for the next challenge ... keeps the mind active and engaged in the task at hand with a goal in mind!
Anyway, FedEx finally delivered my LS 430hp engine and I mounted the Quick Time bell housing and the T56 Magnum ... hoping it would mount into the car but NO .... seems I have the wrong trans tunnel hump from SpeedTech installed in the car. So now I have to remove the cover meant for a T56 and install the hump meant for the Extreme Subframe .... grrrr.
So here's the porn for you visual people ...
That's just some of the cars we get to work on everyday. The VW Bus body work was time consuming, you wouldn't guess that roof is 13' 10" long! The Eleanor was a Holley Sniper install and I got to test drive her ... wow, she'll scoot. Anyway, make the best of everyday and thanks for looking...
The Following 7 Users Say Thank You to Sonar Chief For This Useful Post:
camcojb (04-03-2022), dhutton (04-03-2022), Goosesdad (04-05-2022), Mikael A (04-03-2022), Roscoe03 (04-04-2022), syborg tt (04-04-2022), waynieZ (04-03-2022)
  #1569
Old 04-03-2022, 06:59 PM
Mikael A Mikael A is offline
Congratulations on the job looks like a good time
Mike a
The Following User Says Thank You to Mikael A For This Useful Post:
Sonar Chief (04-03-2022)
  #1570
Old 04-03-2022, 07:33 PM
Looks like a great place to work!
