Originally Posted by randy
Because it’s easy to think your going into 5th but instead you
Go into reverse.
RLO has to be energized to retract the actuator to access reverse. If it's not functioning properly most likely it's not energized (ie, it's going to be a PITA to get it into Reverse).
If it's always energized, it wont block you out of reverse but the gate is still well offset of 5th where that shouldn't be a concern any time other than trying to power shift or slam 5th gear, which most wont be doing.
William
