Go Back   Lateral-g Forums > Classifieds > What's it Worth
Old 05-19-2016, 11:08 PM
colorado80439 colorado80439 is offline
Default Oringinal 68 Camaro 327 drive train
Fresh Professionally Built original 68 327 Camaro RS
Engine 327 .030 over, line honed, Maule coated pistons 10:1, Double hump heads, Comp cam, rocker roller and all accessories shown, intake air cleaner, alt, A/C compressor, headers, electronic ignition, starter, wiring harness, etc
Subframe, powder coated, new bushing, bearings, seals, springs
Quick ratio gear box
radiator and shroud
Disc brakes, brake lines, rear drums, master cylinder all new
1961 date coded, T10 four speed, rebuilt, new clutch, aluminum flywheel
(The car was originally an auto)
12 bolt rear 3.73 fresh rebuilt and powder coat
drive shaft
2.5 inch exhaust never installed
What's it worth!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 05-22-2016, 10:59 PM
Any comments would be appreciated. Thanks
Old 05-23-2016, 07:12 AM
dhutton dhutton is offline
It is worth roughly half of what you have into it. More for the 12 bolt rear.
