Old 09-09-2020, 08:54 PM
andrewb70's Avatar
andrewb70 andrewb70 is online now
Originally Posted by cpd004 View Post
Thanks for the info. Yes...at 956 CFM, I can see why one never turns off while idling at 90+. Loud and annoying. It didn't get hot enough for the 2nd to turn on. It didn't overheat, but I never got stuck in one spot for a very long time.
I haven't had much luck with Griffin. This is the second. The first leaked. Summit replaced it. The second leaked as well in the same place as the first just out of warranty. I had a local shop repair it late last year. So far it's ok, but it may be just a matter of time before it does once again. I'm not duprised that the fans are such low flowing.
My dilemma is either to go ahead and work with what I have as the CFM of both together should be ok, or upgrade the fans alone hoping the radiator holds out. I've spent quite of time ensuring it's mounted with vibration and isolation in mind.
The SS radiator mounts sort of oddly if I was to try and locate the whole thing to try. Plus, who knows how that controller would get along with my E67. The SS is an E38 I believe.
Good info here:
https://www.tbssowners.com/threads/c...ontrol.241568/
Andrew
Instagram @projectgattago
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
cpd004 (09-10-2020)
  #552
Old 09-12-2020, 10:59 AM
cpd004's Avatar
cpd004 cpd004 is online now
So the plan for now is working with what I have. I'll use the Fusion controller and harness to run both of my smaller Spal fans together. They would flow just under 1900 CFM at max over most of the core. I'll see what happens.
My plan is to take power for the controller from a stud in my engine bay that is wired directly to my trunk mounted battery. This is would be a short 4.5' run to the controller. While I'd like to use a single Jcase fuse and 10 awg wire, I can't find one I like. I do have a 60A Maxi fuse and holder that I will use for now. Coming out of the controller, I was contemplating using a distribution block that will wire the two fans. I was thinking of further fusing these two at that block with smaller fuses(30A each), but this may be redundant. I do feel that these would blow much quicker should the need arise over the 60A upstream.
Any thoughts?
1971 Firebird
2017 SS
Old 09-12-2020, 11:14 AM
andrewb70's Avatar
I'd keep it simple and just use a single 50-60 amp fuse.
My YouTube Channel
Old 09-12-2020, 11:19 AM
cpd004's Avatar
Definitely like the KISS method. Iím going to try the 50 and see what happens. On a whim, I have an SS sedan fan assembly coming to check out as well.
1971 Firebird
2017 SS
Old 09-15-2020, 03:58 PM
cpd004's Avatar
The SS fan arrived today. The module does accept the Yazaki connector. Here are some pics in case anyone is interested in sizing:
1971 Firebird
2017 SS
Old 09-26-2020, 02:13 PM
cpd004's Avatar
My plan is to plumb the C6 pressure sensor into one of the two lines going in and out of the condenser. On my Vintage Air condenser, there is a larger (-08 EZ Clip) line on the top of the condenser that comes from the compressor. At the bottom is an -06 line that goes into the drier. From the drier, another -06 line goes into the under dash unit. My understanding is that the C6 pressure sensor should go to the -06 line coming out of the drier as it goes into the main under dash unit.
Is this the correct location for it?
The trinary switch from the initial relay non PWM fan system is at the top of the drier. Is there any need to switch back to the original binary switch or just leave the 3rd wire disconnected?
1971 Firebird
2017 SS
Copyright ©2000 - 2020, vBulletin Solutions Inc.
