Old 05-17-2022, 10:14 PM
Y-TRY Y-TRY is offline
Lightbulb Studs for seat brackets?
I’d like to install studs in the floor to mount my front seats to, instead of bolts. Access is very tight under the seat and the sliders are difficult. Has anyone done this?
I’d envision something resembling ARP header studs, with nut/washer on top. Is there any reason that studs would be more subject to shearing? Any other safety issues?
Thanks in advance.
Old 05-18-2022, 04:20 AM
cpd004's Avatar
cpd004 cpd004 is offline
I've done exactly what you mentioned. I didn't use ARP. I just what I was able to get locally. I also used a locking washer. So far it is easier to drop the seat on instead of digging through carpet.
1971 Firebird
2017 SS
Old 05-18-2022, 12:20 PM
Screaming-Chicken's Avatar
Screaming-Chicken Screaming-Chicken is offline
Thanks in advance.
GM & Ford used studs instead of bolts starting in the early 80's so shouldn't be any safety related issues with studs.
https://screamingchicken.com/
The Following User Says Thank You to Screaming-Chicken For This Useful Post:
camcojb (05-18-2022)
Old 05-18-2022, 11:10 PM
That’s exactly my thought, to avoid digging through the carpet and just dropping the seats over the studs. Do you remember the size?
Old 05-19-2022, 04:16 AM
cpd004's Avatar
I'm sorry, I don't. I can try and look later today if I get a chance or tomorrow.
1971 Firebird
2017 SS
Old 05-20-2022, 08:48 PM
morrisclassic morrisclassic is offline
Lateral-G Supporting Vendor
Default Studs
Hopefully you are talking about screwing studs into the existing factory seat mounting locations
Billy
Old 05-20-2022, 08:49 PM
Default Bolt size
Most GM cars have 5/16 x 18 bolts
Billy
The Following 3 Users Say Thank You to morrisclassic For This Useful Post:
camcojb (05-20-2022), cpd004 (05-25-2022), Y-TRY (05-24-2022)
Old 05-24-2022, 10:33 PM
Billy- Yes, factory location holes. Thanks for the size.
Old 05-25-2022, 04:43 PM
68454RS's Avatar
68454RS 68454RS is offline
Thanks in advance.
I just did the grade 8 bolts, cut the heads off and made studs for my seats, grade 8 washers and nuts.
20220521_134530 by F G, on Flickr
Old 05-30-2022, 05:54 PM
cpd004's Avatar
Here is a pic of mine. I definitely need to vacuum.
1971 Firebird
2017 SS
