Old 03-24-2019, 04:38 PM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
Originally Posted by silvermonte View Post
Quick question, how are you handling the access to the distributor if you need to take it in or out? Im doing an S10 that has massive engine set back like yours and Im almost considering a LS engine just so I dont have to worry about that.
I'm going with a coil on plug ignition but I will be using a distributor for the cam signal. The cap will be a blank with no rotor so it will be a little shorter. If I have to, I'll make a small access panel that I can remove to get the distributor out when needed.
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
The Following User Says Thank You to Yelcamino For This Useful Post:
warhawkchevelle (03-25-2019)
  #82
Old 03-24-2019, 04:40 PM
Yelcamino's Avatar
X 1000.
Thanks Jody!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Yelcamino's Avatar
What a beast! Nice work, Herb. Keep it up!
Thanks Trey!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 03-24-2019, 04:41 PM
Yelcamino's Avatar
Killer Chevelle !
Thanks!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 03-25-2019, 08:06 AM
Pantera1889 Pantera1889 is offline
Looking great! Perfect stance!
Ron
Old 03-25-2019, 11:53 AM
mfain mfain is offline
Very nice project! I did the same thing you are doing - coil on plug with a crank trigger, then a Holley EFI distributor for the cam position signal. My distributor is up under the windshield, but with the motor mounted fairly low I can still get the short distributor out. Question for you - who's front motor plate are you using? Does the mount have a rubber "isolator"?
Pappy
Name:  56 Corvette BB2.jpg
Old 03-25-2019, 07:43 PM
Yelcamino's Avatar
Pappy
Attachment 68675
Thanks Pappy! That's a nice looking engine you got there!
The motor plates are Competition Engineering (C4007), but I fabbed the 1/4" wall tubing, hard rubber isolators, and inner sleeves.
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 03-25-2019, 07:44 PM
Yelcamino's Avatar
Ron
Thanks Ron!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 06-10-2019, 10:57 AM
Yelcamino's Avatar
It's been a while, so this is where I'm at...
20190606_163319 by Yelcamino, on Flickr
20190607_180422 by Yelcamino, on Flickr
20190609_183741 by Yelcamino, on Flickr
20190609_183753 by Yelcamino, on Flickr
I've been welding the joints that I can reach. Now with everything removed, I'm putting it on a rotisserie so I can get to all the hard to reach places and get this thing buttoned up!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
The Following 4 Users Say Thank You to Yelcamino For This Useful Post:
camcojb (06-10-2019), GregWeld (06-10-2019), Roscoe03 (06-11-2019), waynieZ (06-10-2019)
  #90
Old 06-10-2019, 11:53 AM
Yelcamino (06-10-2019)
