Old 10-12-2018, 05:54 PM
xplantdad xplantdad is offline
Originally Posted by kwhizz View Post
"And" paid for !!!! At this point it is close to being the most expensive seat in the world.......LOL
No kidding...and number of years that you have been trying to get it done!
Old 10-13-2018, 09:41 PM
glassman's Avatar
glassman glassman is offline
Got some advice for you. Don’t finish until the night before the long road trip, gotta live by faith lol. Cheers 🍻
Mike
The Following User Says Thank You to glassman For This Useful Post:
kwhizz (10-14-2018)
  #233
Old 12-09-2018, 09:53 AM
kwhizz's Avatar
kwhizz kwhizz is offline
A couple updates...…. #1.... Took Welds advice and sent the original bench seat out to Tracey Weaver to work his magic to balance it out with contoured Foam and keeping the pattern looking some what stock to match...…
#2...… The intermittent clicking issue when trying to start the car ended up being a connection issue at the column mounted neutral safety switch
#3..... the Battery going dead ended up being in the aftermarket ignition switch included in the rewire kit...…… the original 57 Key bezel is still used..... It has Start...Run...off... and Lock on it...…..Unknown to me.... (Probably in the Instructions....LOL )when I would shut off the car and turn the key to the lock position...…. In the new switch it is actually in the Accessory position....When I looked under the dash while fixing the neutral safety switch I noticed that the Dakota Digital modules were lit up...… turn to the off position and everything went out and no more issues...….This Car stuff is Hard !!!!
Old 12-09-2018, 10:56 AM
Good to see you are getting it all figured out!
Old 12-11-2018, 11:20 PM
https://lateral-g.net/forums/post_th...oken=154459176
Glad it wasn't a big issue to fix. It's got to easy some time.
Old 12-12-2018, 06:10 AM
kwhizz's Avatar
A usual problem for me....... I make everything so complicated I can't see the obvious !!!
Old 02-17-2019, 09:58 AM
kwhizz's Avatar
Time to fix another issue that came up with this particular combination...… I bought a Concept1 front drive system while putting the car together. After final assy it turned out that the single belt front drive setup was designed to run everything off the forward positioning of the Super Charger drive pulley. This had all the pulleys and tensioners in that forward position. After the Radiator and fans were installed, everything fit but just barely..... If something would have happened on the road there would have been some major issues having access to the components on the front of the engine..... An uncomfortable position I didn't want to put myself in..... So...… In looking at the other set-ups that are available, I decided to get purchase a Wegner LSA drive.....A two belt set-up that will provide a lot more access for maintenance in this particular application...… So... If you are going to need a LSA front drive set-up and install it in a car that has more clearance in front …… Here is a 100% complete Concept 1 system that has only a couple thousand miles on it and you can save a lot of $$$$$...… LOL....
Here are some ongoing pic's of the change over
New Wegner assy
Radiator out …… Concept 1 unit ready to come out....
You can see where the fan was making contact with the Tensioner
I have a harmonic Balancer puller in the garage some where......LOL......Waiting for the new one to show up so I can get this one off and start the re-install..
Old 02-19-2019, 03:03 AM
warhawkchevelle warhawkchevelle is offline
Hi! Been following your project for a while in silence.
looks like a well thought build and nice car
is that thermostat housing a custom piece or can I order it somewhere, got some space issues right there with my bracket for the supercharger and it looks like that would solve it
Old 02-19-2019, 05:28 AM
kwhizz's Avatar
The Billet Thermostat housing is from Concept1...….
Ken
The Following User Says Thank You to kwhizz For This Useful Post:
warhawkchevelle (02-19-2019)
  #240
Old 02-19-2019, 07:41 PM
kwhizz's Avatar
Moving along...… Got the new Harmonic Balancer installed...… LS engines are a treat in changing these......LOL.....Finished up with the drivers side install..... The Wegner unit is very well engineered..... But.. It is much wider than the Concept1 assy...…. Gonna have to remake the inlet Tube and move the Intercooler pump and change some of the power steering lines to clear the Belt...Here's today's progress
