Old 10-13-2020, 12:02 PM
spazegun2213 spazegun2213 is offline
Default Backspacing for a square setup
Alright guys, I'm doing things a bit backwards and letting my wheels define rear axle width.
My have a '71 Fbody subframe from Speedtech, and I'm using their rear TA setup with DSE mini tubs.
So my question to you all is if I wanted to run a square 315/35/18 setup what are the backspacing numbers I should be looking at?
Old 10-13-2020, 11:02 PM
Swain's Avatar
Swain Swain is offline
You should measure the front space you have from the mounting surface to the fender. Is the rear end shortened ?
You can email me at [email protected]
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 10-15-2020, 11:11 AM
I don't have any of the front bodywork mounted yet, sadly. Which is why I was was asking if anyone had this setup and could toss out a number. I'm not concerned for a perfect fit just yet, more looking for a ballpark.
