Old 06-16-2021, 11:34 AM
dhutton dhutton is offline
Originally Posted by colorado80439 View Post
I ended up using this resistor
https://www.mouser.com/ProductDetail/284-HS3001RJ
And this diode
https://www.digikey.com/en/products/...4S1-D3/5068422
They both qualified for the parameters we were looking for and the packaging was convenient for mounting.
The front windows now work at the same speed up and down.
Thanks again for all the awesome assistance
Those are some serious parts. You know what they say. Go big or go home….
colorado80439 (06-16-2021)
  #22
Old 06-17-2021, 07:02 AM
And this diode
Nice. any chance you can put up a quick draw of how its wired? Which feed which side of switch ect..
Old 06-17-2021, 07:27 AM
colorado80439 colorado80439 is offline
Sure I can verbalize it easier than a drawing, but the switch has 2 wires to the window regulator motor. One up and one down, the resistor is put in series with the power down wire and the diode is in parallel with the resistor. I had to play with the diode direction to get it correct.
