Old 01-19-2020, 12:50 PM
dhutton dhutton is offline
Install your hood without the latch in place. I think you might find the header panel crown is low and once you get that right the latch will fit better. At least that is my recollection from the last time I dealt with this.
Old 01-21-2020, 08:56 PM
Sonar Chief's Avatar
Smile Update 1/21
Wish I could help with the hood latch. You've come a long way. The car is looking great! Keep up the good work.
Thanks, wished it was done already, lol!
Originally Posted by JD67SS View Post
So what’s the new part? The Core support?
That’s my guess at the problem...
Let me know if you need measurements for anything
JD
Thanks JD, all the metal is GM except the AMD hood.
Originally Posted by joeko23 View Post
Your aftermarket front clip should have 2 locations for bolting up the front core support. The first location (closest to the firewall) should be for 67-68 camaro and Novas and the second location a few inches forward should be for a 69 Camaro. I think you just bolted the core support in the 69 Camaro location. I may be wrong but on my Chris alstons frame it has 2 locations to bolt up the core support. If that doesn’t work I would just bend the latch assembly since that’s what looks like is pushing the header panel forward that 1/2” or so.
Thanks for chiming in, I double-checked everything ... read - loosened all the bolts and doubled checked the fitment. The fender can't go back any further cuz the bolt by the hinges,
and the cowl and fender alignment is spot on
I aligned the AMD hood the best I can and the gaps seems ok, might need a little tweaking but overall not bad ...
Seems silly but I started pushing the car by the radiator support and by golly it flexed quite a bit so I bolted the latch support loosely and pushed the latch into place ... hmmm, who would have thunk it!
More progress today ... my body man said to use a BFH and a piece of wood to get the AMD trunk lid to sit flat with the window panel. So I beat on her til she's pretty close to being flush with the front and the corners came up to meet the quarters, "winner winner, chicken dinner"
Thanks for chiming in and thanks for looking ....
The Following 3 Users Say Thank You to Sonar Chief For This Useful Post:
Che70velle (01-24-2020), dhutton (01-22-2020), syborg tt (10-23-2020)
  #1473
Old 01-22-2020, 06:37 AM
Steve68 Steve68 is offline
I helped my friend rebuild a Jag, took the parts from another Jag, when the hood didn't line up, I held the one corner and he pulled and jerked the hood into position, laid 4x4 on there and pushed on the corners all while it was freshly painted!
Old 01-23-2020, 12:24 PM
I know it's crazy how much the metal will move without distortion. Last week I would have told you that there is no way that latch would fit in that hole, but it did, guess GM knew what they were doing
Old 01-26-2020, 08:46 PM
Smile Some fab work 1/26
Been overthinking an ECM / relay/fan controller mount ... so I just got some 22ga Al sheet and started fabbing something up that would fit in the passenger hole. I do thank Scott (SlowProgress) for his replies, I started thinking I could use the template he made ... but with the inners things were different.
So this is what I came up with, KISS, I will need to transfer dimensions to some thicker Al of course and use some rubber bushings to mount the fender side plate.
Thanks for looking ...
Goosesdad (01-27-2020), Spiffav8 (01-30-2020), syborg tt (10-23-2020)
  #1476
Old 01-30-2020, 02:08 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Jeepers!!! I'm off Lat-G for like 5 min and you practically finish your car. I'm impressed with how far it's come and the level of detail. It's paying off HUGE!!!! Keep at it man!!
Curtis
Old 01-30-2020, 10:07 PM
Cool
Thanks bunches, as Greg has always said: "Just pick up a tool and get something done!"
That came out just as I envisioned .... don't know if that's good or bad, but it's mine and I did it.
Got my Mittler Bros 2" punch and flare die this evening, so why wait, right?
Testing
Layout the best I could, nothing fancy!
Some Redneckery bench work, had to bend with a 1/4 radius ...
Think it came out ok, still need to drill and mount stuff.
Gonna be a shame to cover this up with equipment, but it did strengthen the Al quite a bit.
The Following 2 Users Say Thank You to Sonar Chief For This Useful Post:
orangevert (01-30-2020), syborg tt (10-23-2020)
  #1478
Old 01-31-2020, 07:41 AM
DWC's Avatar
DWC DWC is offline
That piece came out great.
Daniel
The Following User Says Thank You to DWC For This Useful Post:
Sonar Chief (01-31-2020)
  #1479
Old 01-31-2020, 11:44 AM
Panteracer's Avatar
Default 67 Camaro
Chief,
That looks great.. you are inspiring me
to get my New Dimple dies out of the box
and get going
Bob
Old 01-31-2020, 04:53 PM
Cool Thanks
Originally Posted by Panteracer View Post
Chief,
and get going
Bob
Thanks, the first time I'd ever dun this, it came out nice [read: after I did some straightening, too close to the edge caused a little warpage] Now get your dies out and build something cool
waiting for pics!
