Old 04-17-2015, 08:53 PM
Smitty68 Smitty68 is offline
Default 68 Camaro A/C evaporator bracket?
What are some of you guys doing as far as mods on a smoothed firewall and using the Detroit Speed 69 Vintage Air bracket to fit the 68. I'm installing the gen 4 unit and cannot find anything but the older compaq smaller system brackets being used in the 68's.
Old 04-17-2015, 11:40 PM
130fe 130fe is offline
Post
Are you using the sure fit one or the universal Gen IV? I have the sure fit one and it came with brackets. They bolted to the ac unit and attached to the inner dash area.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 04-18-2015, 12:37 AM
When I smooth firewalls I like to make a reinforcing bars that weld to the back side. It makes a great place to weld studs to for mounting the evap units using the Vintage Air mounting plates.
Old 04-18-2015, 06:14 PM
Thanks for the reply Chris, I plan on using the sure fit gen 4. I was under the impression that one or more bolts protrude through the firewall? If not the DSE bracket won't be needed???
Old 04-18-2015, 06:22 PM
Thanks for the pics and help Vince. I have the finish coat of paint etc.. Already on the firewall. Did you add those after paint?
Old 04-18-2015, 06:59 PM
Thumbs up
One of the bolts would normally poke through the firewall. A little planning and welding the bolt like Vince talked about will solve that problem. Mine is welded in 9for my smoothed firewall. make sure you weld before you paint ;-)
Chris
1968 Camaro SS
LS3/T56
Old 04-19-2015, 01:06 PM
jwcarguy jwcarguy is offline
Banned
Smitty,
I use the template that is supplied with the sure fit kit, layout the intended holes
The ones that are to be drilled through the firewall, I use 1/4-20 elevator bolts and weld them to the inside of firewall at the location ( I attached a pic)
You are basically reversing the mounting , by making a mounting stud, rather than a through bolt setup
You maybe able to carefully stitch weld one in place prior to final finish??
hope this helps,
Jeff
Old 04-26-2015, 05:09 PM
if your already painted find a spot where you can bridge from to create a mount. Theres a spot between the firewall and floor pan where the subframe bushing support that you can weld to. Will not be visible from the engine side.
This car I made a bracket that used the bulkhead mount and a bolt at the frame bushing reinforcment to support the evaporater. The stud was welded to the plate. Turned out to be overkill but kept the firewall clear.
The Following User Says Thank You to Vince@Meanstreets For This Useful Post:
Sonar Chief (01-27-2020)
Old 04-26-2015, 11:09 PM
SlowProgress's Avatar
This is timely I just started playing with the DSE 69 bracket for my 67 and just posted up where I am so far in the build thread. I like Vince's stiffener idea to make sure the flat firewall doesn't oil can. What do you guys do for the glove box ? I am trying to save as much of the stock looking glove box as possible. If you have any head on shots you could post it would be appreciated. I am not really sure my A/C unit is in the right location yet ?
Old 04-26-2015, 11:11 PM
Banned
looks too far towards the center of the car
