Old 12-16-2020, 08:59 AM
1Bad68Cat 1Bad68Cat is offline
So I just wanted to give an update. Power steering appears to be fixed. Had the truck aligned yesterday. I replaced the steering gear box and there was a night and day difference. The old gear box felt almost like a manual gear box (when cold), but was precise. Of course when the vehicle warmed up, the steering was worse than a manual gear box especially with the wide front tires. The new gear box felt closer to a typical power steering gear box. The power steering fluid did not get hot so I was able to remove the gen 4 camaro power steering cooler. I will be driving the truck more often to see how it pans out, but everything looks on the up and up.
Robert Icasas
Projects:
67 Cougar
Art Morrison Sport IFS
3-link Rear Suspension
Coyote w/ D&D Performance Viper t56
Build: https://lateral-g.net/forums/showthread.php4?t=50170
Brother's 1966 Mustang Restomod
Mustang II front suspension
Torque Arm Rear Suspension
Ridetech Shockwaves
5.0 w/ Viper t56
The Following User Says Thank You to 1Bad68Cat For This Useful Post:
Beechy (12-19-2020)
Old 12-19-2020, 08:31 AM
CraigS CraigS is offline
Glad you got it fixed and thanks for letting us know the solution.
