Old 04-03-2021, 12:30 AM
Jr's Avatar
Jr Jr is offline
Default Fuel level with Holley dash
Hello,
Does anyone know which parts/wires I need to install a fuel level gauge using my Holley dash? I have a ricks tank with the tube level.
Old 04-03-2021, 01:08 PM
camcojb camcojb is online now
Not sure which dash you have, but the standard 7" uses a tan wire for the fuel sender. It looks like the dash comes with everything needed to hook up to the Holley EFI system and display what's happening there. But for additional inputs like fuel level you may need to get a separate I/O harness from Holley to have the wiring needed, not sure if it comes with the dash itself.
https://documents.holley.com/199r10954rev2.pdf
zz430droptop67rs (04-03-2021)
Old 04-03-2021, 05:35 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
What he said^^^^ separate input harness needed.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 04-03-2021, 05:40 PM
Jr's Avatar
Jr Jr is offline
Yes, I have the 7” dash. Which input harness do I need? Does anyone have a link? I tried searching the Holley site...
Old 04-03-2021, 05:44 PM
cjfirstgen's Avatar
https://www.holley.com/products/gaug.../parts/558-432
And one of these then terminate what wires you need into it. Don't forget pins if needed.
https://www.te.com/usa-en/product-14...mpaignId=37423
The Following User Says Thank You to cjfirstgen For This Useful Post:
camcojb (04-03-2021)
