Old 09-23-2013, 06:23 PM
samckitt's Avatar
samckitt samckitt is offline
Default Mounting GMPP harness fuse box?
How are you mounting the fuse box?
Scot
86 Monte SS
LS2/T56 Magnum
Old 01-10-2016, 01:37 PM
randy randy is offline
anyone have any under dash mounting ideas? This would be for a 67 camaro
Old 01-10-2016, 06:48 PM
not much room under dash, especially if you have a Vintage air unit. We put them on the fender well near the factory battery location.
Old 01-10-2016, 07:55 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
X2. Same here. If you mount under dash access is extremely difficult to access.
I move battery to trunk and mount fuse box in OEM battery tray.
Old 01-10-2016, 11:36 PM
I wouldn't mind it there the problem is the harness isn't long enough to then extend it inside the firewall so the wires come behind the engine.
how are you guys hiding the wires where they crossover from the fender to the engine?
Old 01-10-2016, 11:59 PM
Another thought is to mount it above the glove box liner facing down. Make a plate that bolts under the dash pad that the fuse box mounts too. If i need to mess with a fuse i can just remove the top section of the glove box to access.
Another idea is to put it on the left of the glove box and cut a opening in the glove box
Old 01-20-2016, 08:25 AM
gcordova22 gcordova22 is offline
Hello, Do you have any pictures how you mounted the fuse box. Running stock harness with no mods. many thanks
68 camaro ls1, 4L60E
Old 01-30-2016, 06:36 PM
so how is everyone hiding the harness if the fuse box and ecu are in the passenger fender area? Harness doesn't look long enough to run it back inside the car and behind the engine.
Old 01-30-2016, 07:11 PM
Efi69Cam Efi69Cam is offline
The fuse box used is from the late 90s GM trucks with vortec engines. They have a plastic fender well mount bracket that can be modified to fit. I cut the long mounting legs down and build a bracket that bolts to the holes the battery tray mounted to. This allows easy removal of the box for service etc.
Old 01-30-2016, 08:19 PM
ok but how did you run your wires to the engine without being seen crossing over the firewall?
