Old 09-18-2020, 04:51 PM
wonkiernickel wonkiernickel is offline
Default T56 Magnum Shifter Recommendations?
I have a T56 magnum paired with an LS7 clutch and LS3 with cam upgrades in my 1969 Camaro and looking to replace the stock shifter while everything is out. The stock shifter is leaking and is a little sloppy.
I have seen older posts with some shifter suggestions but wondering if anyone has any fresh ideas and experience with what is currently available.
I have talked to Bowler about theirs and it sounds like they have fixed the leaking issues. I am also looking at the Hurst Blackjack and American Powertrain White Lightning. If you have any experience with shifters that don't leak and feel great I would love to hear about them. Thanks in advance!
Old 09-18-2020, 05:12 PM
I have bowler and it’s working great. Shifts feel tight and what I was most worried about, NO LEAKS.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
2018 GMC Denali HD
The Following 3 Users Say Thank You to will69camaro For This Useful Post:
anguilla1980 (09-22-2020), WILWAXU (12-03-2020), wonkiernickel (09-18-2020)
Old 09-18-2020, 05:20 PM
Just what I wanted to hear. Thank you!
Old 11-15-2020, 12:42 PM
pannetron's Avatar
pannetron pannetron is offline
I have a White Lightning shifter from American Powertrain on my T56 Magnum and like it a lot. No leaks after four years and 5,000 miles.
The Following 2 Users Say Thank You to pannetron For This Useful Post:
camcojb (11-17-2020), wonkiernickel (11-16-2020)
Old 11-16-2020, 01:56 PM
Thanks! I ended up ordering a Bowler and will circle back once the LS swap is complete and I've been able to use it for a while.
Old 11-17-2020, 04:20 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Looks like I need to order the Bowler one and have it readily available.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
will69camaro (11-17-2020)
Old 12-02-2020, 03:59 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Has anyone used Silver States SST STX shifter? I ran one on my T56 and didn’t have any issues with it. Decent shifting, but I don’t have much to compare it to. Would greatly appreciate any feedback or reviews.
https://shiftsst.com/stx-tremec-magn...e-shifter.html
Curtis
Old 12-02-2020, 02:53 PM
ADY's Avatar
ADY ADY is offline
my stock t56 shifter was leaking and went with the hurst blackjack... still experienced leaks with the blackjack and even after Hurst sent me a replacement under warranty I still had the same leak via the inner boot of shaft of the blackjack. I tried replacing the vent cap, but still seeing the leak, so going to try installing a simple filter vent and see if the lack of back pressure will stop the shifter leak. Frustrating...
-Adam
1968 Camaro SS
The Following 2 Users Say Thank You to ADY For This Useful Post:
Spiffav8 (12-03-2020), wonkiernickel (12-02-2020)
Old 12-02-2020, 03:07 PM
Yikes. I almost went with the Blackjack shifter. Hopefully the Bowler is the answer we have all been looking for!
Old 12-02-2020, 03:11 PM
ADY's Avatar
ADY ADY is offline
The Hurst technical support said he'd never heard of an issue with leaking, so that's why I'm chasing the venting. Starting to wonder if I should try blowing compressed air through the vent and remove the filler bolt to see if the vent is blocked.
-Adam
1968 Camaro SS
