A few pics and some info:
General:
Year:1973
Make
ONTIAC
Model:TRANS AM
Curb Weight : 3,873 w full tank
Race Weight : 4,080 w full tank
Chassis:
Front Suspension:Stock springs, KYB SHOCKS, POLY BUSHINGS & arm mounts
Rear Suspension:Stock springs, KYB SHOCKS,POLY BUSHINGS
Rear Axle:3:42 Posi
Brakes:Front stock, REAR DISK WS6
Wheels & Tires:AR TTII,17" X 9.5 , 5.5” BS "FRNT & REAR, 285/40 REAR, 275/40 FRNT
Misc:CE SUB-FRAME CONNECTORS, aluminium body mounts, alston front chassis braces, POLY CONTROL ARM & SWAY BAR MOUNTS
WS6 fast ratio steering box, (12:1) with small rag joint
1 ¼” front sway bar, 7/8” rear sway bar
Paint & Body
Color:WHITE, CLEAR/BASE
Graphics
HOENIX GRAPHICS
Interior
Seats:Custom Stock
Upholstery:CUSTOM STOCK
Carpet:STOCK
Dash:INSTALLED FACTORY AC in NON AC CAR
Gauges:STOCK
Shifter:HURST COMP PLUS
Stereo System:ZAPCO JBL & SONY, MEGA WATT!
ADDED FACTORY PWR WINDOWS & DOOR LOCKS
Engine, Fuel, Ignition & Transmission
Type:455, .035, 530 HP, 570 lbs Tq
Camshaft:COMP CAM HYD ROLLER 236/.520” intake, 242/.550” exhaust, 110 sep.
Cylinder Heads:EHEADS PORTED 87cc, flow 307,215
Valvetrain:HARLAND SHARP RR 1.5
Induction
ERFORMER RPM, PORT MATCHED
Fuel: 3/8 lines carter electric pusher with carter mechanical feeding 800 cfm Cliff modified quadrajet
Exhaust Doug's Headers, Flowmaster American Thunder system
Transmission:M21 with poly mount
Cooling:BCOOL WITH 2-10" ELECTRIC FANS, push, stock flex fan ,pull. AC pulleys
Mity Mount engine mounts
10 bolt posi rear, 3:42 ratio
MSD 6AL Spark Box
MSD Billet Distributor with polymer gear
MSD Blaster Coil
A work in progress!
