Old 01-13-2006, 01:35 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I'm running Baer's new 6S system. 14" all around assisted by Hydratechs Hydroboost Unit.
Old 01-15-2006, 12:53 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Default Brakes
Hydraboost w/ a C5 master cylinder.
Front:
Touring Classics Hybrid (C5 Caliper using C4 style rotor due to wheel clearance issues). Two-piece Eradispeeds.
Too bad I can't get the AFX for this combo.
Rear:
Baer Track w/D&S rotors.
Nothing spectacular, but the target weight is only 2750lbs w/ half tank.
Old 01-15-2006, 01:13 AM
Kendall Burleson Kendall Burleson is offline
that a big set of brake what size is the wheel. how much do they weight
Old 01-15-2006, 02:46 AM
You can. You just need to have a little patience.
Tyler
Old 01-16-2006, 02:32 AM
ohcbird's Avatar
TYLER for president!! woohoo! Sorry for the poke...
Patience? Yup- damn thing is up in the air & will be for months. Any expected time? I'm guessing you guys are into your second batch or so?
If you really are making them, $ign me up.
Old 01-28-2006, 09:13 PM
SSDan SSDan is offline
Default brakes
Contrary to the trend, I went agains Baer. I know they have good brakes, but after calling 3 or 4 times, getting put on hold from hell and the rep I talked to was on Pluto..I called Wilwood. The service was fantastic.
I ended up buying the Wilwood brakes from Global West with their Cat 5 system suspension for the front and rear. I added the hydoboost, because I run an 8-71 BDS Blower and they work wonderful!
Old 03-13-2006, 12:58 AM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
I have the B-Body Spndle with 12" 1LE Slotted Rotor and Hawk HP Plus pads
11" Rear Disc Brake and Hawk HP Plus Pads
This car stops hard for manual brakes.
100-0 185 ft
60-0 110ft
I have the Hydro boost system but have installed it yet and expect it to do better
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
