View Poll Results: Which Trans is best for my '69 Firebird?
TKO 500 5 1.43%
TKO 600 91 26.00%
T-56 195 55.71%
Richmond 17 4.86%
Other 42 12.00%
Voters: 350. You may not vote on this poll
Old 12-24-2009, 07:30 AM
BeCool68's Avatar
BeCool68 BeCool68 is offline
Originally Posted by Ron Fox View Post
Are you running a Hurst shifter? Do you have a console?
Can you hear the whine of your transmission over the roar of your motor?
Thanks.
Ron, the Long Shifter is the way to go on this tranny. They have truly designed/engineered a great shifter and is the shifter of choice from Richmond.
I run with a 3 chamber flowmaster so that my bride will ride with me. This has really helped with taming down the engine noise. But when you step into the throttle you will need to prepare for takeoff and hold on, an almost violent roar occurs from this beast.
The whine is not bad at all from the tranny, just tells me a well built tranny is behind this bigblock.
Old 12-24-2009, 06:47 PM
tony byram's Avatar
tony byram tony byram is offline
TH 400 with a GearVendors overdrive
Old 12-26-2009, 08:00 PM
66LS7's Avatar
66LS7 66LS7 is offline
Randy, what type of car did you put the magnum in? Did it fit right in or did you have to modify?
Thanks.
Hi Ron, the Magnum T-56 was installed in our 70 Camaro project "Re-Peeled". The only thing I had to do was cut a hole for the shifter.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
Old 12-28-2009, 11:15 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
When you say a Long Shifter is this a Hurst Long Shifter or one specifically for the new Richmond?
Does you new bride like riding in the car even if you get on it a time or two? I think my girlfriend is somewhat afraid to ride with me and the car is not even built yet. My daughter is ready to get up and go.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 12-28-2009, 11:16 AM
Ron Fox's Avatar
[email protected]
1-262-347-9741
Was your '70 Camaro an automatic or did you just make the trans hole larger?
Thanks.
Ron
Old 12-28-2009, 05:40 PM
66LS7's Avatar
Thanks.
The Camaro was an automatic.
[email protected]
1-262-347-9741
Old 12-29-2009, 08:11 AM
Ron Fox's Avatar
If anyone chose "Other" in the poll above please tell me what trans you prefer and why.
Thanks.
Ron
Old 01-02-2010, 09:02 PM
BeCool68's Avatar
Thanks.
Long shifters are there own brand allowing far better adjustability to make sure you don't miss shifts. gb
Old 03-09-2010, 07:26 PM
bob442 bob442 is offline
what was the intended use again? if its anything other than cruising i would stick with the t-10 if thats what you have. IMO, if not, go with a 6speed, i've read the internals from the camaro fit in a tr400 for a SBC application. i dont know if someone else has mentioned it or ask, but i thought i would add my .02
http://www.tciauto.com/Products/TC-'Street%20Transmissions'-0.aspx
I'm not a fan of the t-56, but thats my opinion, they havent erned a rep for me unless there a rebuilt version like Tremec T-56
Old 03-21-2010, 04:48 PM
Ron Fox's Avatar
The intended use is to have fun with the car by cruising, long distance rides, and maybe the local and close by autocross, etc.
I am not even close to buying a trans but at the moment I am leaning towards the TKO 600. Hopefully Greg is proud of me (just joking with you Greg)
Ron
