Old 12-02-2009, 03:08 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
Default L & H Kustoms Pro Billet Tall Spindles
L & H Kustoms is proud to announce our new Pro Billet™ Tall Spindles. Designed to fit the 64-72 A body, 67-69 F body, and 68-74 X body platforms, machined out of ultra strong, lightweight 6061 T6511 aircraft spec aluminum with an ultra strong billet spindle shaft machined from 4130 Chromoly steel. They come anodized black for the ultimate in corrosion protection. We offer 2 versions, 2” drop and stock height. They are designed to utilize either your factory 69-72 disc brakes components or in conjunction with our C5/C6 corvette disc brake conversion kit which includes billet aluminum hubs and billet aluminum caliper brackets. The tall spindle incorporates a raised upper ball joint to greatly improve the vehicles handling characteristics by transforming the camber gain to improve handling. The Pro Billet™ Tall Spindle bolts directly in place of the OEM assembly to either aftermarket tubular control arms, and with the use of hardened 304 Stainless upper and lower ball joint inserts, any taper needed can be machined into the ball joint insert.
Features include:
- Tall spindle improves negative camber gain under suspension load
- Machined from ultra lightweight, exceptionally strong 6061 T6511 aluminum
- Press-in hardened 304 Stainless ball joint inserts prevent wear and fatigue
- Revised geometry bolt-on Pro Billet™ steering arm improves bump steer (available seperately)
- Direct bolt-on spindle replacement for A-F-X body vehicles
- Available in 2” drop and stock height
Patent Pending
PROUDLY MADE IN THE USA
Retail $750.00 per pair for the spindles
We are offering a group buy of 10% off thru Dec. 31st for all lateral-g.net members Please contact us for details
In Stock Now!
We are also working on Offering these spindles for 2nd gen F-body and the G-body/S10 and they will be available in january.
Luke Mau
L & H Kustoms
