Old 11-20-2010, 10:39 AM
MODO Innovations's Avatar
Default 1970-81 Camaro door lock install kits
This kit is designed to fit the 1970-81 2nd Gen F-bodies. Just like our MI 900 for the 1967 F-body and the MI 910 for the 1968-69 F-body, this kit is designed to use the MES actuators supplied in our MI 700 keyless entry kit.
Included in each kit are powder coated steel brackets, fixture formed 304 stainless steel rods, rod clip for passenger door, hardware, detailed instructions and drill templates.
The drill templates locate the mounting hardware for the brackets. The mounting hardware is hidden behind the door panels. The brackets are manufactured so that they place the actuator out of the way of all the internal moving window mechanisms. The brackets also place the actuator in the proper alignment with the latch. The kit utilizes the unused hole in the door latch as the hook up point for the supplied fixture formed actuator rods. One end of the rod is manufactured to fit into the actuator and the other for the latch. (there is a driver’s rod and a passenger’s side rod and clip) The driver's side latch has an hour glass shaped hole and the rod is designed to fit into this hole and lock itself in place. On the passenger's side, the rod clip snaps into this unused hole, then the rod into the clip. With a ¼ twist of the clip, it snaps over the rod to secure it into place
The price for the kit is $64 + $12 shipping (there will be a price increase on 1/1/11)
To order call 940-391-9002 or buy online at our website.
Below is a picture of the door with the partial skin removed so the installation can be viewed.
Shannon
Modo Innovations
940-391-9002
Old 11-20-2010, 02:50 PM
coolwelder62's Avatar
Shannon,That's cool.I will call you on mon. I want one of those for my 72 camaro.Scott
Old 11-20-2010, 04:18 PM
awr68's Avatar
awr68 awr68 is offline
Another great product! I can't wait to install mine! Very nice piece!
Tony
'68 Camaro
Old 11-21-2010, 09:49 AM
Sounds good Scott.
Thanks Tony. Have you got your to do list in order yet for when Karma makes it home?
Shannon
Modo Innovations
940-391-9002
Old 11-21-2010, 11:48 AM
skatinjay27's Avatar
o damn... sorry shannon for not getting back to you i checked out my passenger side then saw that you wanted to see the driver side one and the car is just to close to the wall on the driver side to get the door open enough. but anyways great product i'll def. need this when the time comes.
AJ
Old 11-23-2010, 09:58 PM
No problem AJ. It all worked out.
Thanks again,
Shannon
Modo Innovations
940-391-9002
