Old 10-15-2011, 01:10 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default Hotchkis 67-69 Camaro/Firebird Rear Sway Bar & Chassis Brace
  • Improve the cornering performance and traction of your 67-69 Camaro or Firebird with the Hotchkis Sport Suspension Rear Sway Bar. The tubular adjustable rear bar design allows fine tuning roll stiffness to improve handling balance and traction. The kit includes rear sway bar, TIG welded reinforcement brace, TIG welded end-links with easy to lubricate polyurethane bushings, premium mounting hardware including, u-bolts, laser cut axle mounts, polyurethane sway bar bushings, grade 8 bolts and gloss black powder coat finish. PROUDLY MADE IN THE USA.
  • Note: Rear sway bar may not be compatible with 1967 models with factory traction bars.
Features:
  • Strong, Lightweight Tubular 7/8” 3 Hole Adjustable Rear Bar
  • Includes Chassis Max Rear Reinforcement Brace
  • Greasable Sway Bar Bushings and Mounts
  • Fabricated Dog-Bone End Links, with Grease Fittings.
  • High Quality, Grade 8 Hardware Included.
  • Durable, Gloss Black Powder Coated Finish.
Benefits:
  • Increases stability and reduces body roll by increasing roll stiffness.
  • Improves Traction and Handling Performance.
  • Rear bar offers two adjustment options allowing handling balance to be tuned compensating for larger rear tires and front/rear weight bias.
  • Bolt-On Installation
$589.95
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
