Old 10-23-2011, 10:24 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default 1967 – 1969 Camaro/Firebird Coil-Over Conversion System 1st Generation F-Body Single
1967 – 1969 Camaro/Firebird Coil-Over Conversion System 1st Generation F-Body Single Adjustable Front Pro Coil System
Suspension Height Adjustment0.0-2.0 in. lowered frontCoil-Over Kit PositionFrontRecommended Front-End Weight1,701-1,900 lbs.Shocks IncludedYesAdjustable ValvingYesInternal DesignTwin-tubeGas ChargedNoNumber of Valving Selections18Extended Length (in)12.8 in.Collapsed Length (in)9.0 in.Threaded Adjustment Range3.000 in.Upper MountStudLower MountBar pinShock Body MaterialAluminumShock Body FinishClear anodizedBushing MaterialPolyurethaneBushing ColorBlackCoil-Over Springs IncludedYesSpring Rate (lbs/in)550 lbs./in.Spring FinishSilver powdercoatedCrossmember IncludedNoAdjustable Mounting Bracket IncludedNoHardware IncludedYesWelding RequiredNoQuantitySold as a kit.NotesSingle adjustable coil-overs, designed to fit applications with small block engines. Shocks are remote ready, they can be used with the QA1 two or four channel remote adjustable system.
These QA1 Pro coil-over systems are engineered from the ground up to offer unmatched performance over stock suspension setups. Pro coil-over systems utilize adjustable and non-adjustable coil-over shocks and springs, designed specifically for replacing the factory shocks and springs. This combination offers ride height adjustment and variable position valving adjustment (where applicable) for performance not found in other kits. Choose these QA1 Pro coil-over systems for your next suspension upgrade.
QA1 offers its Pro Coil System with single adjustable shocks for the daily driver. Compression and rebound adjustment is made easy with one easy-to-reach knob for simultaneous adjustment. With 18 valving options, you’re able to fine tune your suspension for the ride you’re looking for.
  • Made in the U.S.A
  • Easy, Bolt-In Installation
  • Coil-Over
  • Ride Height Adjustable
  • Lightweight Aluminum
  • Remote Ready
  • 100% Dyno Tested and Serialized
  • Rebuildable and Revalveable by the QA1 Factory or QA1 Authorized Service Centers
Starting at
$439.95
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
